EMULSIFIER MEANS
La La Land
umm..Bobbles, you ran that 47 blower at 1600 rpm
a fookin 36 blower @ 3200 rpm has more guts :oldrolleyes:
Actually I ran it at 1650...so what' yor point I was suckin in plenty air...MY tm
Was sealed tight
La La Land
You'd be hard pressed to keep up with us Bob.
I think the best compromise is a "low dose" of in tank or inline injected emulsifier that will adequate for areas NOT hit with the prespray.
An example is behind furniture after the center is presprayed.
I've heard tales of cleaners using trigger sprayers or wonky inconsistant pump ups, and then randomly hitting a room as if cleaning in the dark.
Yes...names changed to protect the guilty. .....lol
La La Land
My Dad was a one step in tank cleaner back in the day, if it was extra dirty he'd 2 step and prespray a room with his wand before extracting.
No vacuuming either that was what the customer did.
He had lots of happy repeat customers.
But couple extra steps do make massive difference to the job and your rep if your competition doesn't
Yes. ..that is what I call prespray. ..lol
Loren Egland
Antioch, California
Loren Egland
B
These are some pictures of the one step method back in the day. Steam Way Powermatic, Steam Way Wand, Steam Way Formula A detergent through the truck mount.
La La Land
Yes....delusional when I GAVE you that 45 and in denial when you didn't even thank me.....happy frickin birtday....!
Ohh I'm jus kidding ....Larr thanked me profusely. .....he's treating me badly so I jus figgered I'd yank his chain. ..
Plus he's upset cuz I forgot his birthday. .....damn it Larr ...I sent you the frigging Nanno wax....whatya want...blood?
Reactions: Dolly Llama
CJ-FL
Florida
CK-FL
Question : if it' so wrong.....why do all the big multi truck guys use the process.....hth could they stay in business this long and have the great reputations they have?
I believe Chester must be the only Stanley guy that doesn't emulsify...if he's telling the truth. ...
I never said we didn’t use an alkaline cleaning solution. We pre-spray with an alkaline pre-spray via hydroforce, agitate via CRB (only in 2 of my 8 locations), rinse with an alkaline solution (8.5 - 9.5 ph) with a Dwyer setting at 7. Let me add that I have 1 location that strictly does a freshwater rinse after pre-spraying.
La La Land
Up here in Mi....the Stanley guys don't carry a vacuum cleaner and they all emusify along with THE other two big companies
Reactions: CJ-FL
CJ-FL
Florida
CK-FL
:eekk: You know that's a lot right?
To be honest no I don’t really know. But theoretically wouldn’t the judgement of “a lot” or “a little” depend on the exact formulation of what’s being applied?
Not trying to agree or disagree and it may be a lot but I would think that the “appropriate quantity” would be dependent upon what the product was. Maybe I’m over thinking it.
La La Land
Yor right Chester. .it would depend on how you mixed the product..
I ran one cup per fi gallon jug and set the Dryers at four....it was powder...
Best stuff ever
Doug Cox
Delavan, WI
Doug Cox
[QUOTE="jcooper, post: 4564999, member: 40117")
However, any cleaner worth a grain of salt has much greater expectations then the client. Hopefully that's the case with most here.[/QUOTE]
Not true.
I always use a alkaline rinse. Have been doing it for years and get excellent results with no resoiling problems. Most of my business is repeat customers so I am familiar with their soiling problems. I use a mild alkaline prespray, 9.5-10 ph and similar ph rinse. Testing the carpet afterwards, the pH is usually neutral. A clear water rinse does not necessarily remove all of your prespray.
Reactions: ruff
IL
I'm sure you know what you are doing, not trying to bust your balls.:lol: Don't listen to the bottle if you have the meter at 7!
Not true.[/quote]
:headscratch:
