Wrong:Define Wrong
I used a 20" pad to make the cimex circles. All I had was beige cimex pads, and I needed something more aggressive and green was the only color I had. My 17" pads were too small to cut the correct size neededWere you able to make those 3 out of 1 pad?
I would’ve done a similar process also, but I didn’t have time to train my 21 year old tech female how to wrestle with a 175. And this carpet is so old with ground in dirt, I think a crb wouldn’t be heavy enough to suspend all that packed in soilI’ve learned to prespray with Free and Clear from Bridgepoint, scrub with either a CRB or 175, and HWE to get it back to zero. Then I will consider using my Cimex on the next go around.... I feel it’s important to REMOVE the ground in soil and left over chems. I have no desire to continue down the last guys path....
But of course a GOOD, SLOW, VACUUMING first, to remove as much sand and dirt first. ‘Professional janitors ‘ don’t seem to feel it’s necessary to use a vac with a beater bar.... then they wonder why the carpeting looks like shyte....I’ve learned to prespray with Free and Clear from Bridgepoint, scrub with either a CRB or 175, and HWE to get it back to zero. Then I will consider using my Cimex on the next go around.... I feel it’s important to REMOVE the ground in soil and left over chems. I have no desire to continue down the last guys path....
Then I would have shower fed the Free and Clear through my Cimex, THEN EXTRACT....I would’ve done a similar process also, but I didn’t have time to train my 21 year old tech female how to wrestle with a 175. And this carpet is so old with ground in dirt, I think a crb wouldn’t be heavy enough to suspend all that packed in soil
I shower fed bridgepoint’s encap through itThen I would have shower fed the Free and Clear through my Cimex, THEN EXTRACT....
I didn’t know women couldn’t push a cimex and move hoses aroundWhy did you take a woman to do a mans job?
It must be some Texas type of reasoningbest 2 employees I ever had were women.
Me too, well at least I paid them.best 2 employees I ever had were women.
