Matress Cleaning
GeeeAus
Grant Baverstock
I do a few of these. Body fats, blood noses, period blood, pet / human pee. Fun times.
But they are really quick so they pay terrific.
I use enzyme pre-spray, pH 10 and some oxy powder together. Mix super hot and apply really heavy on any pee. Mist over body fats and yellowing with ammonia based protein spotter. Agitate it all in with horse hair and dwell 15 minutes.
Then rinse really hot. I generally use the Steam Chamber because it’s so much faster and gets so hot. Some jobs the ShearDry is better.
What do you do to get good results?
We use Prochem's Fine Fabric as a precondition agitate with a horse hair brush and rinse with All Fiber Rinse. Sapphire Upholstery Tool cleans without over wetting.
* Check the dyes on all mattresses including the boxes. They weren't designed to be cleaned, so the dyes can be weak. Too high a ph, too much agitation, excessive rinsing may damage or remove color on some fabrics.
I generally say no or refer them, by the time someone wants their mattress cleaned my charge is more than the dirty scuzzy thing is worth.
The exception is some of the hotels and motels I look after that check the mattress between each guest. Decon30 prespray, light mix of decon30 in spotting machine rinse, HP spotter mist if neccessary, in and out less than 20min with a minimium charge.
Not sure what mattresses go for down there but one can easily spend $1,500.00 -$3,000.00 for decent set.
Reactions: GeeeAus
Yep similar price range, but most the private ones I see are 10 yrs plus that you wouldn't let a dog sleep on. Its a $50 mattress at best with stains..
Problem is the drycleaner I've been referring has started sending me referrals..
I'm gonna have to explain the unwritten rules :lol:
CJ-FL
CK-FL
Is this the small rotary style tool in your video? Would you mind posting pictures of a manufacturer’s link?
Reactions: GeeeAus
I do about the same as Grant upholstery pre spray loaded with peroxide for pee and protein based stains!
Rinse with upholstery pro and last step!
Or any all fiber rinse drop a dry pod and boom it’s done
Reactions: GeeeAus
If you rinse hot, would that set the blood into fibers?
Reactions: GeeeAus
Im not always successful with rust remover in removing blood.
Reactions: GeeeAus
I've never had trouble removing blood but it's a bleeder no pun intended
Rust I've only ever had a problem on some wools
Reactions: DAT
What are your thoughts on cleaning memory foam? We currently don not.
Provided your not dousing it in prespray I'd PRESUME it would be "ok" the reason I don't like doing mattresses are the soiling on them are generally biological and deep within the foam. Easier to get biologicals out of carpet and pad IMO
And just think of those IDIOTS who allow their DOGS to sleep with them!
Talk about a peetry dish!
Isn't freaking Nebraska, the puppy mill capital of America?
Can anybody here guarantee that Ludo ain't one of them puppy mill owners?
Reactions: Mike Pailliotet
GeeeAus
Grant Baverstock
IF you do loads of bedding, partitions and flat upholstered surfaces this tool ROCKS.
It is NO GOOD as a GENERAL PURPOSE tool.
But IF you clean beds etc, get one.
GeeeAus
Grant Baverstock
@Mikey P the jizz I’m pretty sure is protein. But ammonia can still turn tgis into soap that water will rinse out.
I mostly find body oils turn the mattress yellow. Just simple sebaceous secretion from the skin .
I have done a couple on special needed basis and also for a furniture store display memory foam bed.
They do take a long time to dry.
