Andrew from Simply Clean
- Apr 25, 2018
- 77
- Name
- Andrew
Hello everyone I'm new to this forum and was hoping for some help. I purchased a 2008 Butler System with a brand new engine and transmission a couple of months ago. Now the RPM's are too high and the drive shaft is vibrating more than normal. Called Butler and they said that the Tachometer might be reading wrong and that's all they could think of because you can't adjust the RPMs on these "newer" versions of the butler it's all electronically controlled. I have an appointment on Tuesday to get all the belts replaced by my mechanic. But I'm concerned about the high RPM and drive shaft vibration...any ideas?
Thank you
-Andrew
Thank you
-Andrew
