My new fave way to clean wood..
Sweep
Spray neutral no rinse down
Scrub with Contec pad
Mop with white Contec Micro
Follow up mop w/blue Micro
Fan dry
Beautiful!
Virtually no risk
Gets corners and edges
No heavy machines.
20180605_132408.jpg 20180605_132419.jpg 20180605_132612.jpg 20180605_132718.jpg 20180605_143122.jpg 20180605_132159.jpg 20180605_135817.jpg 20180605_142646.jpg 20180605_134457.jpg
Reactions: Josh
the results look good but to me it looks too much like what the home owner can do themselves (gotta put on a show)
I break out the 175 and spray buff away on lightly soiled wood with a white or red pad.
Or mop on a neutral and scrub with a red/green pad, flat mop again and run a brush on the 175 for heavier soiling. And yep edges with old floor pads cut to fit flat mop
Reactions: Acp
Most people lazy enough to pay to have their wood cleaned, are not home when the low life janitor is around.
I usually use a HS wand but this floor has big ol gaps in between the slats
Reactions: Doug Rice
Acp
Bjorn Marshall
I think if they did see you doing it they might not be impressed and wonder why they paid 75 cents/sq ft lol
youll have your customers buying bona mops the next day lol, seemed to work well tho with those pads
They're more than welcome to.
Hell, I even send them a link to my blog so they can but the mops and cleaner.
The same stuff @SamIam tore my ass up over last night because he doesnt pay attention...
Bona commercial cleaner, 13" cotton pads and the Oreck jiggler, final mop with 24" micro pads...
Why Bona?
it's no different than the neutral cleaner that your local janitorial sells and is waaaaaaaaay cheaper. $10 for 144 gallons of RTU
J Scott W
Jeffrey Scott Warrington
I do like cleaning with the Contec pads. If you use the Hydro-Force Wood Fresh Neutral Cleaner the customer will know you are using a product meant for hardwood. The Wood Fresh label is so much better. And what is a few bucks when you are making 75 cents a foot.
https://interlinksupply.com/index.php?item_num=CW025GL
Noble Carpet Cleaners
good question, because I want my customers to see the product that they can get local and keep their floors cleaner between restorative cleanings. the amount I use is small.
Bona no good, and you still want extract with with freshwater somehow.
full disclosure I use this https://www.amazon.com/Bona-Professional-Hardwood-Concentrate-Formally/dp/B00CBYAAL2?th=1
and at the same time keep a RTU jug from home depot on board. When you mix from concentrate it's the same color as the RTU
from the store, just a whole lot cheaper $4/gal vs $20ish/gal. I like to hammer home with customers who don't know sh.. about
keeping their flooring clean. This way I can point to the jug, point to the store and they've got no excuses. About half of them
listen to me.
Why Bona?
I got a cleaner for $30 a gallon dilute 2 oz to a gallon. Nyco brand. Trying an environment friendly bathroom cleaner too that's $36 for 6 quarts.
