I don't know - vehicles are usually sold or written off at about 300/350K (about 180/210K in miles) before they need doing
Saiger" data-source="post: 4587022" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">over 100,000 to 125,000 and still same brake pads
GTFO.....
given more carful thought .
It might be at 60K+ for front
My pick-up was bought used , don't know if pads were changed, but recently replaced them when I heard 'em grinding @ 75k
E-250 Super Cargo was bought new... 3 sets front, one set rear in 180K
Momma's ride just turned 67K..original pads
They're about due
Brakes are cheaper than transmissions.You guys don't utilize the 1st and 2nd gears of your automatics ?
since it's for momma
GTFO.....
They're about due
51 on mine..We sell trucks at 75 to 85k. 1 ton GMC vans with fresh water tank, front pads at 60k. Never do the backs. 3/4 ton GMC vans w/o fresh water, never do the brakes. Seattle has hills like San Francisco. An under 600 pound CDS helps. The mega-slide ins run upward of 1,000 pounds dry, double that with water on board.
Our FedEx guy said his Transit has the brakes replaced every 15k, almost as bad as the early Sprinters. I've also heard complaints that the OEM brake pads wear fast and recommendations are to use a heavier duty pad when you have the brakes done. Or, learn to change pads yourself. Should be a 30 minute job in the driveway.
Can't imagine you under your Audi.. Should be a 30 minute job in the driveway.
