sealcanvas
Did you know your "Standard Seal-A-Door" can be used in tall (8') doors? And it's quick and easy to use! Take a peek: www.sealadoor.com
Sorry Steve, we have nothing for the arched doorways.How about tall doors with a half-moon opening at the top?
No magnet but it's spring loaded so you can compress a side and remove that side easily. I have the zipper and window...both extra options... When I am setting up I just leave the zipper open...or partially open so it opens easily. When I'm all set up I go to work with it zipped.Do they all have zippers, or do they use magnetic strips? As a BDPH I of course wouldn’t know.
But I would want a self-closing magnetic opening, or both zipper and magnet strip.
Maybe find another entry?Sorry Steve, we have nothing for the arched doorways.
Exactly. Thank you!Maybe find another entry?
Houses must have more than one.
Thank you Bob...that is exactly correct. We have "tested" magnetic strips and even larger magnets...and the results have been totally unsatisfactory!No magnet but it's spring loaded so you can compress a side and remove that side easily. I have the zipper and window...both extra options... When I am setting up I just leave the zipper open...or partially open so it opens easily. When I'm all set up I go to work with it zipped.
It would have to be a very strong magnet to contend with the air pressure changes from air conditioners in the home and a blowing storm outside as an example. Works very well as is.
