tmiklethun
- Aug 18, 2009
- 285
- Name
- Travis Miklethun
Still consider the best. I used to see people talk about here, but not much anymore
I haven't used hardball"s in awhile. Hardball is good, But My go to is now Cobbs Solvent Protector. They are similar in they don't need to be diluted. Cobb's is also great for sealing/impregnating grout and Tile. Apparently their Stone and tile impregnator is the same stuff as the carpet protector. So it's nice to just have one protector on the truck.
The Solvent Protector is a little less than their Ultraseal. Ultraseal has 40% more flourochemical so if you apply the Solvent Protector at 600sqft per gallon (Solvent Protector's directions say 1000sqft per gallon) you have the same performance as the Ultraseal does at 1000 sqft per gallon. No real reason I switched from Hardball except maybe price ( always free shipping when you order a case) and convenience since I often order other Cobb products. Also I prefer the solvent based carrier over the waterbased, in my head the solvent based would give a better chance for even coverage if my spraying/application isn't perfectly even. I think Cobbs is the best value 4 gallons for $106 shipped
Not just showers but anywhere you use it, wear a respirator and evacuate anyone else in the home.Same here! Just good stuff..
BUT PROPER PERSONEL PROTECTION NEEDS TO BE USED IN CONFINED SPACES LIKE SHOWERS OR YOU WILL THROWN FORVA LOOP.
It was definitely Board de jour - perhaps on the one day you have missedI don’t ever remember it being all the rage.
Here or even on ICS
I swore by HB for a couple years
Than that nasty solvent they use forced me to stop.
Much.Is it worse then Cobbs solvent? What did you switch too?
Thanks for the input to all.
The challenge is not the performance, but the speed of penetration into the grout lines and spread across the tiles so that it is a fast process. Also any remaining residue on the tiles would be more evident using a water base than solvent base. Thanks, for the question as I have an idea for a potential starting point. However, for every product introduced there are a few that died in the lab.Tom do you think its possible to create a water base slop and mop grout sealer?
I bet people with renal failure, their urine would clean better.Good thing your Dad lived in a post soap era Jim
Urine For Cleaning
In the grand scheme of things, soap is a relatively recent invention. Before that, people had to make do with what they had on hand, and in ancient Rome, if you wanted your clothes really clean, you used urine.
A Roman laundry was called a fullo, and it employed boys who would walk on clothing that was submerged in a mixture of water and urine. The urine was partly from animals but mostly human, collected in jugs placed on street corners for citizens to make their contributions. The fulloes placed such a great demand for urine on cities that in some areas, they were required to pay a tax on the urine they collected.
Because of the harsh treatment, the garments were often further treated with other substances to restore their color; white linens were rubbed with a white dirt called cimolian. In ancient Rome, urine was also used for cleaning something else: teeth. Teeth whitening used urine to bleach away stains.
