MB PMF Grinder
Shane T
Shane Tiegs
Ok I'll say it up front, "I'm an idiot". Been using this tool for a couple years now and never realized that it didn't have an inline filter for the solution line. Now one of the jets is plugged. I've tried using a small wire from a wire brush and air pressure to no avail. Any suggestions or do I have buy a replacement?
Ok I'll say it up front, "I'm and idiot". Been using this tool for a couple years now and never realized that it didn't have an inline filter for the solution line. Now one of the jets is plugged. I've tried using a small wire from a wire brush and air pressure to no avail. Any suggestions or do I have buy a replacement?
careful poking jets with needles when chunks are stuck hard
It'll jack up a brass jet pretty quick ..jack up stainless too
Try submersing it in muratic acid
(available at in the lawn/garden section at HD or Lowes)
....I "think" that's where I bought mine
That's worked 100% for me
.L.T.A.
Take off the Y and try compressed air from the tip end
what is it?
POS plastic they're they use too much of in over priced tools??
muratic acid soak
or do it the hard way ....:icon_rolleyes:
...L.T.A.
Remove the jet and try gently cleaning with the wire from the brush, often tee jet cleaners are too large. When you can pass the wire easily through the jet, wash it under a tap and blow it out with an air compressor.
this thing?
what kind of PITA is it to pull the jet?
have an extra jet for field expedient clearing
(when a thin beading needle won't clear it)
Hint, poke the thin beading needle while triggering
if it fouls again within minutes, you need to pull the jet anyway and flush the valve/line
and toss a stuck hard fouled jet in muratic ...trust me
..LT.A
Shane T
Shane Tiegs
I've done that . I'll try some acid.
I marvel that one of you creative moghuls hasn’t invented a good inline strainer with QC to use INLINE so you can catch this stuff inline before it hits the jets. And if it is already out there, what’s the issue in using one?
I’m gonna ask my chemical
Pimp tomorrow.
Shane T
Shane Tiegs
I
Pimp tomorrow.
I've got inline filters on all my other tools just never noticed this didn't have one. Not sure why manufacturer would sell a tool without one. This what the manifold and jets look like on this tool.
Reactions: Old Coastie
Shane T
Shane Tiegs
I rarely need to clean out my inline filters so I wouldn't want a QD.
I have other toilet bowl cleaner that's stronger but the works works on stainless or brass for me.
Sometimes you can find a nylon brush that the bristles will fit the orifice. Not sure about that tool though.
I had something get into one of my little Jets at one time. Make sure you plug off the other jet when you're trying to blow backwards the material out of the other jet. It will not clear out if you do not do that
Haven't tried that yet. Been using my back up unit and it has a max psi of 600.
close the ball valve on solution line, crank the PSI, then trigger tool valve before opening sol line valve
close sol line valve before releasing tool valve
won't blow the tool valve that way
I have a toolbox full of spare jets.
Poking wires into them to clear them is usually a waste of time, just chasing the symptom instead of the cause.
hey you retarts...
its O-ring disintegration...!!!
possible hosedelamO
