360i quit working
Josh Almanza
Josh Almanza
I tried using my 360i today and when I went to squeezing the trigger to spin the head, nothing happened...of course, I replugged it in another outlet and nothing happened again. So, I made a quick observation to see if anything out of the norm was visible,saw nothing. Basically when you try to trigger the power on it only spins for half a second...it kept doing this over and over every time I squeezed the trigger. What do you think might be the problem? Thanks.
Acp
Bjorn Marshall
switch is bad, or the screws in the handle where the switch is are too tight.. loosen them a bit. If they are too tight the switch will do that or get stuck on lol which is even worse
Reactions: Papa John
GeeeAus
Grant Baverstock
It’s possible the switch is to blame but it sounds like the unit will start reliably for a fraction of a second and then stop which sounds like the control board.
Give Dave or Brad at Rotovac a call. They’ll look after you.
Acp
Bjorn Marshall
damn still getting that scuffing sound when tipped back going right to left... new felt gasket, new motor, what else can even be replaced the head and shroud are new too lol.
We were loving the 15inch head on the 360i because its so light weight and covers sqft fast but now Im wondering how many are out there actually running the 15inch head.
Rotovac tells me theres lots of cleaners using 360i with 15inch
Reactions: GeeeAus
GeeeAus
Grant Baverstock
There are; were I not on a portable I would be using it myself
Latest Auctions
