- Feb 4, 2016
- 14,592
- Name
- Matt w.
I did the rag method on it. I'm just worried if it starts running down the side, that it might make ugly lines. I tested a spot and it didn't do anything, but I'm just worried it might show up laterI think you might want to see what sort of acid it uses. If I had your motivation or the time, I’d use a rag dampened with it rather than spraying it willy-nilly all over that expensive wrap.
How did you make it do that?
I rubbed aluminum brightener on it..............How did you make it do that?
lolI rubbed aluminum brightener on it..............
photoshop...poorly done
It’s a 8x10 box. You’re right, I don’t know if I could go back to anything smallerHey Matt, how big is the box? Ours is 14 ft. with a liftgate , and with all the equipment and accessories we carry it couldn't be any less. I can't imagine working out of a van these days.
I called them first. They told me they didn’t knowtalk to guys who applied your wrap
them not knowing would be the equivalent of you asking a customer what prespray you should use
