- Oct 7, 2006
- 15,253
- Name
- Jimmy L
I want to flush my blower. How do I do it?
The operator was a heavy WD40 user. I quit using WD at that point and just flush the blower several times a year.
That is my understanding to. After I finish the last job of the day I remove the vac hose lid and let the unit run for a couple minutes to dry the blower off. Cleancos might be designed different from some units, their blower basically hangs off the side of the waste tank so getting rid of any moisture is fast.My understanding that the WD40 is used to flush the water that may have gotten on the blower lobes to prevent them from rusting.
He's gonna want to flush right into the blower filter holes, the lube hole is about 1/32" no helpful amount of water is going to flow thru that.if you have a lube port
run a stream of clear water into a HOT blower for 30-40 seconds til the mud brown gunk is light to white
Tell her a dirty joke?I want to flush my blower. How do I do it?
You know canola/cooking oil leaves a film and gets sticky af right?, or even, something like Wessen Oil.
Someone told me to mist a prespray into the blower opening at the filters. Run it at the upholstery setting. Run about 5 gallons and then run clear water thru. Run it at high setting to dry it out. 03 quad 56 here
put a cast iron frying pan on the stove, heat it up, then throw it in the sink full of water, what happens?
IT WARPS!!!!! Same thing with the lobes on your blower......
That’s just what I was told by the manufacturer.... IDK, that logic totally makes sense to me....
TM.be a whole lot of crashing lobes if so.
I'm sure there's more than few that have sucked water from the waste tank
don't know how hot a lobe gets under load
But bet it's not hot enough to sear a steak ...or warp a heavy, thick chunk of cast
BTW, blower manufacture, TM manufacture or disty?
WHAT are you running Mattel blowers?If you put a cast iron frying pan on the stove, heat it up, then throw it in the sink full of water, what happens?
IT WARPS!!!!! Same thing with the lobes on your blower...... only thing a guy should run into his blower is LPS TKX lubricant.... 10-20 second spray, run the blower for 5-10 min. Without the vac port covered to dissipate any residual lube, and to dry out any remaining moisture .... that’s what I’ve been told..... I think I’ll stick with that advice....
1. Your blower is not getting even close to the temperature of the frying pan.If you put a cast iron frying pan on the stove, heat it up, then throw it in the sink full of water, what happens?
