HOW TO FLUSH A BLOWER?
I believe chemtex makes a portable TM on wheels that uses a 33 blower.
It has NO waste tank but blows out the water thru the blower
Cooler water will decrease the diameter of
The rotors by a few thousands which will allow the crap to release off and blow out
Better...
A hot blower and cold water is all I ever did. 5 to 10 minutes of a slow steady stream of clean cold water. Usually enough detergent already in the blower from my experience.
I stick a garden hose right before the blower and adjust flow by the sound. I probably use 10 to 15 gallons of water. Run it dry another 10 minutes then a little lubricant at the end.
Then tell her a dirty joke.
As long as ya got it in the hole
You may as well
