- Feb 4, 2016
- 14,551
- Name
- Matt w.
wrong answer. Try againit's an intelligent tester.
Is that all? Dang. I was hoping it was a pressure adjuster. This isn't an amtex wand. There's no need for thatIt's a bypass control knob. You can really get that tool smoking hot very fast.
I’m gonna need to experiment with that feature. I always triggered off and on and the tool gets so hot, sometimes it’s hard to hold the Handle. If this bypass makes it hotter than that, I’ll just leave it off.Yes there is. How hot do you like to clean with? I liked it so hot I wore rubber gloves. Some people don't like cleaning that hot, so you dial it to your preference.
Most cleaners trigger off and on as they clean. This will keep the hot water from ever getting to the fabric. With the bypass you get the heat to whatever temp you like consistently.
Makes sense. So, if I"m doing a job with carpet and upholstery, could I leave the pressure set at 550, and just open the bypass halfway when I get to the upholstery?By creating internal flow, which keeps your available heat flowing to the fabric, it does reduce pressure to the face of the fabric. As you loosen it, you will notice reduced flow from the jet.
Just because it's not a "new on the shelf" tool, doesn't mean it's not new to me. I don't have the luxury to getting all the new tools to test. So, yes. If I get an ancient pile lifter...I'm gonna ask questions to Goobers like you. And I expect to be harassed. So keep it up. It keeps my mind sharp.What's next?
A Pile Lifter?
Dufus.
That's the majority of my upholstery jobs. I needed a second tool for this mega church I do with 900+ chairs. I did that job with just one tool last year and I learned my lesson.Great on Microfiber.
Shoot I just gave away an upholstery pro for a $100 if I liked you I would’ve sent it to you. HahahahahahaThat's the majority of my upholstery jobs. I needed a second tool for this mega church I do with 900+ chairs. I did that job with just one tool last year and I learned my lesson.
And ......it is the only tool in our little industry that will also serve you well when you diversify to carpentryIt's a great flushing tool, just heavy but it will last a lifetime. .....
