Sanitaire or strap dusting
Donwand
Brian
Can someone explain exactly how a Sanitaire upright with a beater bar for dusting rugs works any differently than say an Oreck? Does it still operate like a traditional vaccum and suck the dirt up or does it somehow just beat out the dirt? Is there a reason why I only hear about Sainitaires being used like this or can this be done with any upright? Trying to decide if I should go this route or just buy a strap dusting machine. Thanks
I never dusted rugs with my old sanitaire, but my Royal did a fantastic job when I dusted rugs upside down, due to the weight of the head of it. Since the sanitaire is so much lighter, I don't see how it could compare to it. I've never used a kirby, but it has the same weight, so it might be just as aggressive as the Royal.
Matt Ross
The old sanitair tombstone stylenmetal vacs are cheap and use an actual metal beater bar on the brush roll. Plus the vacuum motors are very large and move tons of cfm, but not much lift. All that makes for really good small particle removal in theory.
But in the real world I cant see how it would be that different than an oreck. Mabye slightly better but either way it's not a rug plant.
You can set up a VibraGroomer 1 bar to be all "knuckles" and no bristle..
I imagine that's what the real rug f@gs do..
Reactions: Donwand
Ron K
The reason I don't comment on the hard surface forum is because I don't
know anything about it, maybe...
As far as the original question some Sanitare vacuums have a beater bar not a
brush roll, the vibration of the beater bar vibrates dry grit/soil out because you
do this procedure pile side down . it is very very effective not at all efficient.
If you clean enough rugs buy a tumble duster. to get out as much dust/dry particulate as possible you should also pre-wash and post-wash dust.
I bought a strap duster then saw red and sold it.
Reactions: Donwand
rhyde
rhyde
I remember saying on the old ICS board that a strap duster wasn't as good as a vacuum with a beater bar on many types of rugs. I'm sure other uprights work well too.
Oh, The VibraGroomer 1 bar to be all "knuckles" doesn't work well at all
Donwand
Brian
I hope you're wrong. I just bought a Sanitaire sc899f with these 2 metal attachments BEATER BAR-LONG #25670A.
rhyde
rhyde
Do your own comparative testing I have all the stuff I'm telling you the standard bar works great
89783
Reactions: sweendogg
