Go to upholstery Juice ?
randy
USA
Randy
Recently my long term favorite upholstery chem was "reformulated ". Looking to replace it. Any recommendations ?
D Luke
MI
Derek
I've never used anything that worked nearly as good as Multi-Steam Upholstery Prespray.
Smells awful, though.
seriously though, when I visited three furniture retailers (a Lazy Boy Gallery, a middle of the road and a higher end and an all natural organic) last week, 95% of all offerings were 95% or more pure Polyester.
All those scary brownoutable, shrinkable designer fabrics from the past are now Ultrapakable....
These are all 100% Poly....
Askal
Paulsen
Al
Preface. Bane clone. I ordered like 25 gallons last time. Are they still in business?
I use a lot of prochems fine fabric prespray and fine fabric shampoo. Works on ordinary fabrics too. Sometimes with a little scrub.
San Francisco, CA
None of those will be as knock out and as fast a cleaner as an ammoniated pre-spray. But it can also get you into some issues.
Kleenrite had a good one and there are other in the market as well. You can also boost your pre-spray with a little non-sudsy ammonia. I hate these pre-sprays smell.
But there are plenty of good ones mentioned above that would work well without the extra risk.
Avenge HD works well but is crazy expensive. About $26.00 per gallon to be diluted 1:1.
There's just no reason to pay that much for an upholstery pre-spray, where you can get pretty similar results with products that cost a fraction of that.
Actually, that one of the things I do with heavily soiled microfibre or polyester is to add some non sudsy ammonia.
Reactions: Hack Attack
I like ammoniated prespray products on synthetics, especially oil loving polyester and olefin.
I'm leaning more toward encap products than shampoo for everything else. They have better oil cutting qualities than conventional upholstery shampoos, and leave less residue. If you try to rinse a fabric you've shampooed, and you have a clear tool, you'll see how difficult it is to really remove all of the shampoo.
Encaps rinse out much easier.
You will get better bonding of your protector when you get better detergent removal too.
Prochem fine fabric gags me. I just use my carpet stuff on most of what I see.
I need to see if I can get the dry volatile solvent still. Best solvent I've found that I don't mind working with.
