- Oct 6, 2006
- 116,776
Lets see how the vacuum gets to the tank and the high water shut off assembly
Hook it up to your truck mountI need to hear that AW29 screaming for dear life!!!
That's about the stupidest thing I've ever heard you say. That's like saying a 1 inch paint brush is the same as a 4 inch paint brush. Obviously, the more power you have, the faster you will clean and and achieve better results. The reason the little 100 psi pump machine recovered the same amount of water is that it took longer to spray it out, therefore taking longer to recover it. That's like saying all truck mounts are the same because they all are capable of 14 inches hg. The more air flow you have at a reasonable lift, the drier the carpets will be. The more pressure and flow you have, the cleaner the carpets will be, in the same time frame. Yes, there has to be a balance. Your pressure and flow is your agitation. The more you have, the better you clean. The more lift and CFM you have, the drier the carpets will be.Remember MF number somethingorother at Mytee and the porty shootout/evaluation?
Ron “OCD” Werner was in charge of it
With his OCDness, I had no doubt it would be as straight as possible
My prediction at the time ?
Wouldn’t be a dime’s worth of difference in any of them .
And there wasn’t
Ed’s Recoil did win by a few drops of moisture though.
The big surprise was the TruckForce whoopty-doo mega port was last by a few drops
Take-away lesson and moral of the story ?
All portys are pretty much the same performance wise .
Paint brushes aren’t .
Wooster are the best
Or if you’re a cheap fook, Sherwin Williams Contractor series are pretty decent and as good or better than Purdy
Mo-rons
..l.t.a.
dont forget the bad breath!Man, back in 2009, everyone was polite on this board. Now, ya all grumpy old farts.
I don't think I'd hire you to paint my house. Iffn I had a house to paint that is. Take an awful long time with that little 1 inch brush.thanks Fred
whatever, Ron
all the numbers CFM, inches of lift, or 22.7786% greater vac from vOOnderbar vac company ...yada, yada, yada don't mean sheeit
what matters is, how much you put down and how much of that did the squirt box recover
they're all pretty much the same
single wand, 100ft of hose with at least a 36 blower spinning at capacity?
they are Ron
But it will be a Purdy brush. Carries more paint per inch...I don't think I'd hire you to paint my house. Iffn I had a house to paint that is. Take an awful long time with that little 1 inch brush
Canadian humor has that effect....Man, back in 2009, everyone was polite on this board. Now, ya all grumpy old farts.
There's enough paint jobs in WhoooopChuck to keep Larry as busy as a chipmunk.I don't think I'd hire you to paint my house. Iffn I had a house to paint that is. Take an awful long time with that little 1 inch brush.
Could you specify, Jimmy?Ed uses "High tech encapsulation" type BS marketing
Clint eastwood?
Past-tenseWhy are these portable arguments so tense?
And there wasn’t
Mo-rons
..l.t.a.
pre-tense when they leave it in the van.Past-tense
There's not one on my dirt dragon,So what happens when the tank is full and the APO isn't working for whatever reason.
Is there a vac motor shut-off?
And there wasn’t
Mo-rons
..l.t.a.
Dude the link said the M5 was the more balanced
