- Aug 9, 2012
- 11,431
- Name
- sam miller
How is the unit heating up the fuel pump? Is the blower exhaust directed at the fuel tank?
Pretty close
How many days in row do you run over 90 and 100 degrees??? You may live in a better climate for one!
It gets a lot hotter than that when the TM exhaust is blasting out under the van. It will melt the 2" hose if it's in the way.Not many fortunately... they may happen once a twice per season
So is your theory that the fuel pump may be failing because of 10 or 20 degrees higher outside temperature?
All the 1200’s I’ve seen are vented straight down.
Yes blows straight down
No, it's Da-monAmen
Tell that to all the chrome fluffers, like Capitoni
So it can go in other platforms?
That why the video showed it cleaning with the hood up?We'll have one to use in Scottsdale
From what I'm told, all the problems have been addressed dramatically, including engine compartment heat.
They have been ignoring the same issues for years, and have found the fixes for all of them and implemented them on this machine?!
