Who else (besides Mike)
Charlie Lyman
Charlie Lyman
is using the 12" Devestator wand? I need some real world feedback before I make my empty nest celebration purchase. TIA
Scott Turknett
I have 2 of each size now. One of each size is on each van. My tech is young, with fresh wrists. He still reaches for the 2” wand. I have been at it for enough years now that I reach for the 1-1/2” wand. It’s a bit easier on the wrists, elbows, and shoulders.
I would by I'm saving it for the Chimps for when their Dang dies.
Itll be the first wand ill buy when i get my tm..
Charlie, get one. The way it is bent lets you drive the swivel head around corners, all the way under beds, into places a straight wand cannot go. It also allows you to hold the wand at a comfortable height, changing as often as you need. This is accomplished by slightly tilting the head from side to side, holding the optimum angle for suction.
Much more could be said, but it boils down to “Charlie, get one.”
Get one, use it, and be happy.
I originally bought it so it would be easier on my helper. now we use it on every job and on stairs. Unless you're Canadian, it works great for stairs.
jack zerkie
I have one the 12 and its GREAT so much vacuum that sometime I have go back to my old wand to finish. But that's due to my old age you young guys no problem for you. So buy one and enjoy it. jz
Are you using a whip?
try backing your Cobb Vac release spring back off of 22"
My swivel is stiff there’s a reason you didn’t want Demo version hahahahah.
It’s like a toy but easier in some places.
Also it’s more maneuverable.
I go back and forth 2 in dev, 1 1/2 inch 15 inch mach15, Prochem 6 jet ti
I also have holed glide for my 14 inch dev and a slot glide too.
I think the 14 inch with both glides is the best of all worlds.
But no matter what I use I’am always tired!
I need more sardines!
