- Oct 6, 2006
- 117,374
Will in Vegas hooked my up to do a project on another military base.
.50 a ft to vlm and $12 a task chair
How did you "capture" that job?Will in Vegas hooked my up to do a project on another military base.
.50 a ft to vlm
don't know enough to be dangerous regarding cleaning with solvent soaked ground corn cob
so this is a serious question...
aren't the costs of material substantially higher?
what about time?
say a 1000sf of moderately soiled wide open area
How much in material and time?
With TM, that's roughly $8-10 bucks costs (not including labor) and an hour and a half time pull up to pull away
A 50lb pail will cover aprox 3000 sqft.don't know enough to be dangerous regarding cleaning with solvent soaked ground corn cob
what about time?
Yep, you can put smaller jets on your wand as well.You can make it last longer
I'm not sure about the Milliken product but Host usually says about 100 sqft per pound. You call also apply a liquid prespray on spots and high traffic areas.From Will..
Really depends on how heavily soiled the carpet is. Light to medium soiling I could get 10k square feet done w one bucket. Main point of it would be to put a little down in higher traffic areas just to keep brushes clean. Residential wise, you can clean 30 standard rooms of carpet with one bucket.
Yup. My experience as well.From Will..
