- Oct 6, 2006
- 117,272
Who else uses Oxy Clean as your main booster?
Are they a board supporter?
Oxy clean is basically borax with peroxide. Borax is a washing soda and can boost your prespray or rinse. Oxy clean will do the same and also help with coffee and similar stains.Try Borax, works better ...
From a Canadian....
See how bright that carpet is after cleaning? Oh, that's peroxide caused fading? Shhhhh.Oxy clean will do the same and also help with coffee and similar stains.
It's even more exciting when your hand held pump sprayer explodes as you're driving.I generally oxy boost for white trash hell holes only
its exciting when your HF starts bubbling all over the lounge where you left it![]()
Mixing a little HOT Dan????I generally oxy boost for white trash hell holes only
that circle in the middle was CLEAN! lolMixing a little HOT Dan????
I use booster powder by harvard. Works great
You are using oxiclean stuff from Walmart? For real?
How much you use per gallon?For 15 plus years
Yes. I am aware of that as well. I just thought chemicals formulated for carpet cleaning generally rinses better regardless of the similarities of it's ingredients.do you know how to read a SDS?
Up to an ounceHow much you use per gallon?
