How does a tech damage an outside spigot?
icleancarpetz
Rafael Samson
Two different customers in the last few weeks hired Stanley Stupid for cleaning. Says they broke the outside spigot. Swore they will never hire them again in addition to rug doctor results.
I don’t get, were the chimps out on banana break during training?
‘Turn right for on...Turn left for off’
I don’t get, where the chimps out on banana break during training?
Probably already broken, just blaming the last guy who touched it.
MLPW
If it's a loose mounted spigot ( I want to spell spicket) that's not properly mounted on the wall with just one hand, I could see them twisting the little PVC pipe and causing a crack or break in it
clean image
Orlando
Carl Maddock
Or the back flow preventers (req to pass inspection) that are defective and swivel..
scotty747
Forgot to fill my tank the other day. First time iv used customers water in years. Made sure I put the freeze cover back on. love having my own water.
Ne
Know more than one cleaner who has hooked up and turned one on and then found out he has flooded the house. Have always carried my own water.
Charlie Lyman
Meridian, ID
Charlie Lyman
It can happen if you're not careful. If that stem doesn't want to turn...... do not force it. Some people will turn it too hard and break it, especially if its frozen.
Reactions: Dolly Llama
If it's frozen, leave it alone. We rarely have freezing weather here but it does happen. Those days I usually hook up in the house. Just be careful there too. After turning the tap on, open the door under the sink and check for leaks. If the outdoor tap isn't frozen and is turned on, it should be good to go. Watch out for buildings where the water has been turned off. It may have been turned off because of leaks. Always ask for permission to turn the water back on.
La La Land
Once when I was young an dumb i turned
The water on.........it turned every water sprinkler in his whole yard on....ohh ya......it was below zero......
Husband was beyond pissed.....
Reactions: FB7777
La La Land
Wrong handle in basement ......ohh it was awful....
I could still hear him screaming as I drove away...
La La Land
Ya...I usually write up the invoice after the estimate..... and jus stand there till they write the check.....
Reactions: Willy P
FB7777
Owner probably should have labeled the spigots in the basement with tags or at least given you a heads up
or were you one of those dipshit contractors that wanders down to the basement turning on water without permission?
Brian H
Detroit Michigan area
Brian H
Yep to all 3 of these by our crews.
