There are no stupid questions...
Meter Maid
The Undetective
Dayton,Ohio
Except this one:
When people say to run a rotary at 300 psi, is that with the trigger pulled or the psi setting on my TM?
I ask because there’s about a 100 psi difference from the setting on my TM when I pull the trigger.
Meter Maid
The Undetective
Dayton,Ohio
That’s what I was thinking, especially if I’m getting only 200-220 with the trigger pulled.
I thought you were Chavez.
Village Idiot
friction loss
and I'm not sure if people adjust their rotaries keyed.......
manual for 360i says 50-300 psi......I'd probably raise it (keyed) provided you are getting good recovery and saw better results
*lowering the jet size/flow will decrease friction loss.....some also have a flow control valve
Reactions: Meter Maid
Meter Maid
The Undetective
Dayton,Ohio
friction loss
When you say “keyed” do you mean increasing my psi at the TM to allow for the loss from friction when I open the trigger?
Reactions: bob vawter
Village Idiot
yes
I am saying that is the reason for the drop and that you could compensate for it
not that you should....
scotty747
I just crack the shut off valve until I get water. Then add more pressure if you need it. No need to soak it unless its trashed.
Trip Moses
IMOL
Savannah GA
Trip Moses
Except this one:
Always set your pressure and your chemical meter with the trigger pulled. Come on, Man!!
San Francisco, CA.
My understanding Is that if you are getting a 100 psi drop when the trigger is pulled then the pressure regulator needs to be replaced.
USA
Matt Middleton
I installed a needle valve right after the Trex quick coupler. Then I can easily control the amount of solution hitting the carpet. It really made a difference to our cleaning and dry times.
