Red stains makes me steamy.
CJ-FL
CK-FL
I had one yesterday from a wicker basket... 🤦‍♂️
  • Wow
CJ-FL
CK-FL
In preparation for our crews arrival, customer attempted to move small furniture. In doing so, she set a wicker basket, fake plant on
The back porch. Crew cleaned. Once they left she put small stuff back. 🤦‍♂️ Then continued to repeatedly move the plant to ensure it was in the perfect spot. Thus leaving not just 1 or 2 but 3 beautifully wicked stains.
I don't think that will come out unless you to the UV light trick for hours and hours. And even that is a gamble.
CJ-FL
CK-FL
I spent about an hour on it yesterday. The lighter ones and the left and right damn near we’re gone (very difficult to see)... the worst one in the middle was probably 50% better but started to have color loss so I called it a day. She was happier with the result than I was but that’s better than the opposite way around. I’ve heard the UV truck come up and discussed by Cobb I think but don’t know anything about it or have ever tried it.
Brad Gouveia
For UV trick you do not have to use a light you just need to have them cover it up with some glass pyrex or something that will keep it wet with the red remover. The UV from the sun will work just need to be wet. I had luck with this method before.
I use large furniture tabs on smaller spots and Reynolds wrap on larger ones. Just have to weight them down. I thought it was because it keeps it wet and working longer.
Thinking of you Marty.
I know you were doing it one handed, but there’s a safer method that I like to do by folding the rag and preheating the rag with the iron before putting it on the stain, and when you put the hot side of the rag on the stain, it acts immediately when applied with the iron on top of that, causing the stain to go away in a shorter, safer period of time.
Like and Subscribe
Yup, 48 seconds is long enough to melt some types of carpet....
Good post Matt.
I’m still stuck on the wallpaper steamer. It takes WAY longer, but it is more forgiving....
Just ask me how I know....
I’m a professional. I don’t leave an iron on carpet for 48 seconds.
UV spotlight is only way I've pulled turmeric, you better have whole house to clean though cos it takes awhile
(I picked this up the next day)
scared tenant wanting their bond back
I only put a patch in with owners permission
Naturally...
There's numbnuts out there that do it without discussing with clients?
yep, haven't seen it for awhile but I've seen it
also had a tenant insist that I do a patch that I refused without talking to owner. A week later I got called by the owner going mad at the crap patch that the tenant decided to have a go at and had handed my cleaning receipt as "proof" that I did it
I don't do many rentals and thats fine
Reactions: DAT
Good post Matt.
I tried using a steamer and the hot water dripping from it was too hot, causing color loss. I know several of the other guys use a steamer also, so maybe it was a faulty tool.
And Damon, fold that rag next time and don't go over 20seconds. recount how long that iron stayed on that carpet while you were blabbering, trying to get a paycheck from youtube
I've only had colour loss on wool.. 2 cough recently
but I mostly mix my own reducers
what brands you using that is causing loss on sinthetics?
Like and Subscribe :)
scotty747
The best I'v found is harvard stain blaster. The bottle looked almost generic but I thought I shouldn't judge a product by the bottle. Sometimes the red is gone after cleaning. Generally I prefer two part products since they stay stable longer. The last ones I bought were from a janitorial store and god knows how many years they were on the shelf.
