Project truck and mount almost done!
Robeson County, NC
Austin Willoughby
So some of you guys might remember me from a few years back. Short back story, I started with a porty a few years ago, then upgraded to a used prochem performer and put into a enclosed trailer. Decided it would be a good idea to redo my performer bc the frame on it had some pretty bad rust on bottom. It became to much of an undertaking although I did quite a bit of it done. Decided this time around to buy a van of some sort and a newer used truck mount. Ended up doing a few things to the newer truckmount to get it up to par. Used the waste tank and water box from my old machine and retrofitted it. So here's some pics of my progress and where I'm at with it now
20191107_183540.jpg 20190927_122934.jpg 20190927_180504.jpg 20190928_184345.jpg 20191002_113901.jpg 20191004_093355.jpg 20191004_093423.jpg 20191005_173713.jpg 20191017_172628.jpg 20191020_152428.jpg 20191021_132513.jpg 20191021_132520.jpg 20191022_165905.jpg 20191023_171747.jpg 20191022_211007.jpg 20191025_124018.jpg 20191025_130623.jpg 20191025_185943_007.jpg 20191025_200302.jpg 20191029_114607.jpg 20191029_185234.jpg 20191030_142137.jpg 20191030_141808.jpg 20191030_191327.jpg 20191031_153232.jpg 20191031_222340.jpg 20191031_222437.jpg 20191031_230839.jpg 20191031_232012.jpg 20191102_151844.jpg 20191102_175514.jpg 20191105_160600.jpg 20191107_123749.jpg
N GA
BradFenstermaker
Wow you have been busy. Lots of TLC but looks like it will pay off.
I need to restore my vac hose reel like you did.
All the room to work and store in your box will be enjoyable. Good Job
Robeson County, NC
Austin Willoughby
Short vid
Thanks man. Yea I'm a bit of a DIYer lol but honestly this was more then I had anticipated. I've been working on it steady for 3 weeks and worked on it about 2 weeks a little when I was full time at my job. Cost about 50 bucks to do the hose reel and really I did a quick job wasn't worried about any variation from the chipping paint. Hit it with a wire wheel then sprayed it with primer then paint
N GA
BradFenstermaker
In 4 days the end of August I bought a new Promaster.
Herculiner for 3 days because it poured rain all weekend and took forever to cure.
Had to reschedule a couple of days. Luckily my neighbor has a forklift. 2 days with help from local Steamer when he finished his days. Gary came over to hold wrenches. I moved my equipment over.
Marty could hang a hammock for on the job naps in my truck.
Still have to hang plywood on drivers wall for tool hanging storage.
Keep after it.
Reactions: hogjowl
Jim Williams
Bynum N.C.
Jim Williams
That's an ambitious project. That's going to be a great setup. Most people would have just gone a$$hole deep in debt and bought new. Good job!
Robeson County, NC
Austin Willoughby
Keep after it.
It's a never ended process but it's so fulfilling the closer you get to the end and of course when you finish one thing another messes up haha. Currently fixing something that I just fixed and it crapped out again 😑
Robeson County, NC
Austin Willoughby
Trust me I contemplated it but after looking at used setups for around 10k and then seeing them in person they always disappointed, so now I can make it exactly the way I want it. If I wanna change something it's easier bc ik how everything is setup. Also I'll know my machine inside and out, and all is kinks. Yay. Probably will have a little more in it then buying used but it will be way more solid and again I'll know it inside and out.
Ron Werner
Ron Werner
I reinstalled my tm into a newer cubevan back in 14. Had a budget crunch plus time crunch so I did a few things and had to redo them. But like you said, in the end I had a very usable tm that I knew from stem to stern. I still tweak it with a part or modification every now and then. Not much really to go wrong. And a new unit would have issues as well but at least I know how to fix this one.
I highly recommend some RVsteps for the back. It'll make getting in and out a LOT easier and may save you from a bad slip. Ask me how I know! Can even walk a CIMEX up and down them. Best $150 I spent on her.
Robeson County, NC
Austin Willoughby
View attachment 94809 View attachment 94810 View attachment 94811
Love it. Will look into to getting some for sure!
Reactions: Ron Werner
Ron Werner
Ron Werner
Ron do I see an old TNT?
If so mine is the same color.
Nope, that is the precursor to the C4, called the CanAm. Bob Foster and Les put this together, engine was on propane and had a 4HT like a TNT, but its a bigger engine and blower than a TNT. Also, the fw tank was supposed to the tank underneath but it was only 80gal and I wanted a bigger supply so that tank never saw any use.
This pic is the original instal in 08.
