If you could only BUY 1?? Rotovac 360i, 360 Xl, Zipper Wand or Zipper SS
RugWorx
MIshawaka, IN
Joe Couch
Invested a lot of $$ recently to go back in the cleaning business after a 5 year hiatus and I will be doing it part time to start off. My question is that if you were primarily doing residential/rental properties and could only buy one (Rotovac 360i, 360 Xl, Zipper Wand or Zipper SS) which one would you go with and why. I already have a 20 inch CRB so this would obviously be used for trashed carpets. Any help would be great.
Andy
No Where
Doesn't Matter
Rotovac 360i; zippers are more for wide open commercial places. The XL even tho it has a bigger diameter the spay pattern is the same as the 360 but leaves a bigger void in the middle that you have to compensate for on rat nasties. Oh and get the brushhead.
RugWorx
MIshawaka, IN
Joe Couch
Are you just using the brush head to pre-scrub?
Andy
No Where
Doesn't Matter
Use the CRB in harmony with your wand with the job calls for it. That I believe is actually faster than the rotovac.
I have both the 360i and the xl. The I with the brush head is what I use on trashed carpets. Lightweight and very aggressive. You can use it to scrub your prespray in or flush/extract or both.
Reactions: Hack Attack
further south than you
I've got a 360i with brush head on the way
I've used an rx20 didnt like it
used an xl and the amount of overlap needed didnt make much sense
used a powerwand, cleans really well but slow
if there was a mytee distributor here I'd have considered the T-rex
scotty747
I bumped a heater vent with my 360 and the gears sheared off. This was 10 years ago. Im sure they've improved since then but still love my heavy rx-20. There's a newer one on the local craigslist for 250.00. Wonder why.
IL
If you have a nice wand, I'd stick with the crb wand combo.
Winter is here, keep your money.
We have the 360i, works great.
Grand Rapids, MN
I have not used a rotary in over a year and a half.
Maybe my clientele...
I Wand a lot.
CRB and wand a bunch (because Conway Devastator Wands Rock!)
Zipper almost all Commercial regular and SS Super Spinner because everything else is just slow as molasses in a Minnesota winter.
My RX 20 has sat in my shop for 8 years. My Rotovac maybe used on the other vans twice this year on a trashed residential....
I'm buying one more regular 15 inch Zipper.
