- Oct 6, 2006
- 117,210
I think Ford did it with their 6.0 and 6.4 Diesel engines. They call it the "delete kit". And they got away with it.Auto makers need to start calling recalls “upgrades”. Good marketing.
I have an old 6.0. I would have hated to be the owner for the first 100000.I think Ford did it with their 6.0 and 6.4 Diesel engines. They call it the "delete kit". And they got away with it.
It still dumps to the waste tank also.The thermol relief valve is on the bottom of the water tank and you plumb it to the top. In reality you are just recirculating the hot water back into the water box?
The new Thermo relief valve pulls all the air out of the thermal well first, which in turn creates higher head pressure for the pump, which in turn makes the seals last longer. Once all the air is pulled out of it, it pulls water out of the top, that way it isn't pulling sediment or hard water deposits that accumulate at the bottom of the thermal well.The thermol relief valve is on the bottom of the water tank and you plumb it to the top. In reality you are just recirculating the hot water back into the water box?
Way too complicated
Worth every penny.My mechanical advice is free too
My tank is filling up in less than 500 sqft.
I’m needing to do this. My tank is filling up in less than 500 sqft. I got yelled at by a landlord for pumping “drug water” on his land. I had to roll up and leave the job.
Derf..
Yes.
You need to hire someone to be in charge of maintenance, bro
So does that mean that the valve has to be changed everytime the wax melts?
Any authorized Legend Brands distributor. https://www.legendbrandscleaning.com/Dealer-SearchWhere can this upgrade be purchased?
