Butler system driveshaft grinding sound
palmettoclean
Give me a call if you are interested in rebuilding it yourself. The bearings cost less than $100, and the clutch is $150ish. I don’t recall the part numbers but the parts are very easy to get. It took me 3 hours to remove, rebuild, and reinstall. 907-350-0999
Hi Scott - I'd like some pointers on this job
sam1904
Sam
I'm trying to move my butler machine from 2006 gmc savana to 2019 gmc savan. Will the drive shaft fit the new van?
Rob Grady
Rob Grady
I am no expert with the Butler units, but it probably will. I hope so, because I am in the process of refurbishing the drive shaft on my 2007 Butler.It was easy enough to split the shaft housing and remove the rear concentric bearing.
The difficulty i have run into is the front bearing and not being able to drive the shaft backwards for the removal of the other two bearings.
I have taken it to a machine shop because I don't want to damage the shaft.
Scott Turknett
You are switching from a mechanical throttle body to an electric throttle body. That won’t be a bolt up transfer. You will need some conversion parts
