Prochem/Comet APO
The last couple of weeks my APO has been acting up. I thought my float was going out so I replaced it, then i thought the wires overheated and were shorting somewhere, so I replaced them. The APO was still acting up.
In frustration I picked it up and bounced it on the floor of the van which caused the APO to spring back to life. After repeating this a few times I figured something was binding in the motor. Tonight I pulled it out took it home to work on. After cleaning out all the check valves, which were moderately clogged, I hooked the APO up to my Jeep battery for a test pump. The motor kicked on but ran very labored. I figured the next step was to pull out the electric brushes for inspection. Sure enough, they exhibited wear. When I pulled them out a ton of fine black powder followed. Using compressed air (from my mouth) I blew out the hole. I then cleaned the magnetic brushes and reinstalled everything. Hooked the motor back up to the Jeep and it sprang to life like new.
Glad I fixed this. These APO’s are almost $2k and a replacement motor from Steambrite is about $450.
@Justin Legend Brands can you send me a link or a phone number of a supplier that can send me the upgraded thermal valve for an 870? I’m finally ready to buy one. I tried to look online and couldn’t track one down.
There is something called a dump valve................use it
HA, Well, The houses I clean at would not appreciate a flood of waste water flooding their perfectly landscaped yards. The APO pump hose is perfect for placing it in a clandestine spot or running into a sewer clean-out 100 ft away. Keep in mind, I'm in hippy California and everyone is jumpy about pollutants.
Andy
No Where
Doesn't Matter
For single operator running an 870 it really doesn't help. I was at a job this week, with a helper, moving the wand pretty steady. In 2 hours the machine dumped 50 gallons of water into my water tank.
Chandler Arizona
Justin Johnston
Hey Damon,
Sorry I just saw this. I know we talked on Facebook, but if you are still looking you can go here and type in your zip code to find a list of dealers close to you.
View attachment 100638View attachment 100639
I need a motor for mine it hums think this would work?
