- Oct 7, 2006
- 49,947
My 100% filthy Glad Pads prove this tilt theory to be bullshit
Speed 5 on the TRS is indeed fast, much prefer speed 3
And if you want to go slow, put it on speed 1
Only the TRInity given you the options
Tamping do work on spotting teqnique...
something heavy OP machines are known for...........
I would guess that the Oreck is more guilty of fiber damage.
No additional lube and needed to go over and over and over to get a somewhat decent result.https://www.youtube.com/watch?v=CdeT6YHiYCc&t=73s
Modifying it to act like a lesser OP by removing the washer?
The "Tamping" action is designed to lift particulates to the surface....pet hair, sandy grit etc
right...Modifying it to act like a lesser OP by removing the washer?
You can't really believe that.
Did you at least take basic physics in high school?Is the washer thicker than a pad?
Stupid theory.
I majored in Animal Husbandry.Did you at least take basic physics in high school?
How is it not fully touching the carpet? The machine is like 110 lbs. What is the depth of the washer, and how many tamping per rotation?Unless you like the idea of your pad never truly being fully on the carpet.
