Go to one step emulsifier!
Mr Brightside
Southern Cali
Jay Wags
What’s your favorite one step rinse I am hoping to rinse some light to medium soiled areas with a one step rinse process for large open commercial areas
what would you suggest
You mean you do to want to prespray? I wouldn't recommend that but something like Procyon plus powder won't leave any sticky residue.
for com?
if you're planing "blow 'n go" ala Stan and the clans ...just encRap it.
cause there is no emulsifier run thru the wand that will clean worth a chit compared to pre-spray, dwell (or scrub) and flush rinse extract.
butt...can tell you Prochem Dry Slurry is an excellent emulsifier with low to no resoil residue concerns
San Francisco, CA
Any of the well known manufacturer's alkaline rinses would work.
In the medium soiled areas and or high traffic areas, not pre-spraying may actually slow you down as it will require many more passes to achieve clean and may increase chances of stains coming back or streaking.
None of the well formulated rinses will cause re-soling if used in the right dilusion.
Mr Brightside
Southern Cali
Jay Wags
Ok I’m a little short handed with techs right now so I was trying to figure out if I can move faster with an emulsifier
I guess prespray ultrapak and dry slurry it is
Reactions: Dolly Llama
There is a cleaning company in my town that only uses Dry slurry and that's it. No prespray. Not sure how they get away with it, but they do. Low hanging fruit.
hell, that's more common than you realize, Damon.
There's a whole chit-ton of successful outfits large 'n small banking jack with that biz model ....Stan, Hogopian and the myriad of low price point/hi-volume wand sawing Yawksters
La La Land
ORRR....you could be jus lik Larry and buy the wrong damn stuff from what he was tol......
seattle
Prochem Dry Slurry, Hydramaster HydraDri or RinseFree, or any other "extraction detergent" designed for just this purpose will do exactly what you want. There are higher alkalinity detergents that are appropriate for commercial carpet as well.
Light to medium soil levels and plastic carpet require pre-spray only on specific spots.
For this situation, extra steps are fluff.
PS: The term rinse has become confusing, as many manufacturers use the term freely to describe products that are detergents and also products that are just rinses.
A rinse is supposed to be a product that helps remove detergent residue, as from pre-sprayed detergent. Anyone using an actual rinse without prespray knows it doesn't clean, and may be confused into thinking that extraction detergent doesn't work and a two-step method is required.
Rob Grady
Sauble Beach, Ontario
Rob Grady
Water is a rinsing agent. And by itself can remove all kinds of soapy residue. It does clean by itself and has been proven to be very effective with the proper tools.
Ne
Many are mislead that a detergent rinse by itself can't clean.
But alas many are just follow the pack type of cleaners.
Chemspec formula 90 was a very good cleaner that dried into a powder that if there was residue it could be vacuumed up
Mr Brightside
Southern Cali
Jay Wags
Maybe I’m a super hack but many situations I have ran a zipper ss at 800psi no prespray just a good emulsifier set at 4gph and did a great job
just wondering what you guys would suggest
We cleaned from the mid 70's until the early 80's with high heat truck mounts, an alkaline emulsifier (first one we used isn't made any longer; the last few years it was Dry Slurry). We had prespotter when needed.
To be fair, back then we were cleaning dirt colored carpet (brown, rust, olive green for the most part).
There is something to be said for the fact that if you can clean with a pass or two and no prespray that the carpet will dry quicker than if its heavily presprayed with an in line sprayer, then rinsed.
La La Land
I jus KNEW you had a skeleton or three in yor closet Jim
Reactions: Jim Pemberton
