Phruken encap soma bich
Go put a gallon of water in your tank and take the driver pads off hold the head level and slowly spin it with the trigger activated and see if water's coming out of the center spout of each head
Reactions: Mr Brightside
looks like you just spread the dirt around
well, duh ..cause that's what it is.
you just need to learn how to get the dirt slurry down to the base of fiber at backing where it's not as obvious.
it ain't rocket surgery and it ain't "cleaning" either.
...If "cleaning" is defined as removal of foreign material
D Luke
MI
Derek
Spots and spills notoriously wick back after Cimexing in my experience. That makes two of us, and apparently only two because everyone else says it doesn't happen.
Yes, I have experience, yes, I've tried whatever product you're about to recommend, and yes I've tried the techniques that "guarantee" no wicking.
Mr Brightside
Southern Cali
Jay Wags
Honestly I think cleaning the same way every time and building good systems is key
Customers and employees always do the same thing and know what to expect
I think encap is something I want to learn more but not sure where it would fit in my biz
i'm still waiting on what the "bucket test" is
is it a comparison of same carpet with bucket from TM and bucket from rinsed pad....
Left to evaporate so you can "really" see how much soil was removed?
or sump'um else?
Is there a hands on class for encap only? It should be different from the normal carpet cleaning tech class
I started me 5 gallon evap test in 06, almost done, wait for the video in 2022
make it a gallon
you're in the desert...it'll take 15 minutes .
don't forget to add the crud from your dev filter too
John Gee played this game 20 years ago
"look how dirty the washing machine water is"
IDGAS if someone pads (and owned and used a shake 'n shine machine long before you got a tingle in your loins from the vibration)
however, It shouldn't be classified as a "1%'er" job ..or even a 10%'er.
It's just "good'nuff" in some situations
Reactions: jcooper and Jimmy L
make it a gallon
20 years ago foam core MF pads weren't around.
Get with the times Mr Carburator.
I padded a home for abused kids yesterday.
Check out what came out of the lint trap...
Today I went back and hit some major traffic patterns that were already zippered with any cap and everything turned out great I think that’s a good combo
Make sure your employees are doing their dry passes. Wet pass one direction, then dry pass over the same area. I overlap by 2/3 of the machine width. So far, it's been working for me.
Reactions: KSL
encapman
St Petersburg, FL
Rick Gelinas
Larry you’re living in the past.
make it a gallon
You are living in the past. Low moisture and encap is very much the present. And the future will look different still. Even Mike is seeing that there‘s a place for low moisture cleaning in residential. Options are always a good thing. Though some folks will stick to their old tried and true, as the rest of the industry moves forward.
sassyotto
Wisconsin
Paul
well when the Carpet Manufacturers tell me Ecap is good for residential, THEN the industry will move forward. Just because some carpet cleaning shmucks say its the latest and greatest aint gunna sway me one bit.
pure and utter bullshit from a janitor and part time suds slinger that went full time soap salesman
encapman
St Petersburg, FL
Rick Gelinas
Not that I really care about your assessment of my business acumen. But when we were in the thick of it, we were running 3 trucks nightly - doing commercial carpet cleaning. Wouldn't necessarily call that "part-time".
Reactions: KSL
