You would be the 3rd cousin.That hurt my feelings
looks like you just spread the dirt around
well, duh ..cause that's what it is.
you just need to learn how to get the dirt slurry down to the base of fiber at backing where it's not as obvious.
it ain't rocket surgery and it ain't "cleaning" either.
...If "cleaning" is defined as removal of foreign material
Have any of you crusty farts done the bucket test?
Is there a hands on class for encap only? It should be different from the normal carpet cleaning tech class
I started me 5 gallon evap test in 06, almost done, wait for the video in 2022
make it a gallon
you're in the desert...it'll take 15 minutes .
don't forget to add the crud from your dev filter too
John Gee played this game 20 years ago
"look how dirty the washing machine water is"
IDGAS if someone pads (and owned and used a shake 'n shine machine long before you got a tingle in your loins from the vibration)
however, It shouldn't be classified as a "1%'er" job ..or even a 10%'er.
It's just "good'nuff" in some situations
Make sure your employees are doing their dry passes. Wet pass one direction, then dry pass over the same area. I overlap by 2/3 of the machine width. So far, it's been working for me.Today I went back and hit some major traffic patterns that were already zippered with any cap and everything turned out great I think thatās a good combo
make it a gallon
well when the Carpet Manufacturers tell me Ecap is good for residential, THEN the industry will move forward. Just because some carpet cleaning shmucks say its the latest and greatest aint gunna sway me one bit.as the rest of the industry moves forward.
Larry youāre living in the past.
You are living in the past. Low moisture and encap is very much the present. And the future will look different still. Even Mike is seeing that thereās a place for low moisture cleaning in residential. Options are always a good thing. Though some folks will stick to their old tried and true, as the rest of the industry moves forward.
You'd never knowLook out
Never piss off a JW!
pure and utter bullshit from a janitor and part time suds slinger that went full time soap salesman
Look out
