upcoming TOPS Phoenix auction
Any sized imo.
I'll be honest and say I never use the term "pad cap"... not even sure what the hell it means maybe you can explain it to me
Any sized imo.
Using a scrub pad instead of an absorbent bonnet.
Well I guess I just prefer to remove some soil
You will remove more soil with a microfiber pad for sure. As long as you change the pad regularly. But encapping with a scrub pad gives you the exact appearance. If it works for a Cimex, which is considered the king of encapping, it works for all of the orbital machines as well.
Mr Brightside
Jay Wags
So would you ever build a small van such as nv200 and an encap crew to go do apartments and commercial work
No truckmount
Tons of chit carpet
And probably piss lots of piss
Mr Brightside
Jay Wags
I don’t think I would either but I would like to setup a van for apartments and things I can’t do with the big vans and let them go to work
But in the end I think customers would complain about the process
Techs would complain about the weight of the machines and I would bitch about how much they complain
I would consider setting up a van like a transit connect with a combination of high performance portable and an orbital. Portable for apartments and orbital for cgd. Get you in the underground parkades.
Reactions: Sierra Clean Care
Mr Brightside
Jay Wags
Ya that’s true
But I hate portables LoL but if my guys were doing it then maybe lol
That’s a good idea Ron...
I just might see how well that works out...
For a large metropolitan city, you would never run out of work. Tons of condos with lots of Upholstery even if carpets are on the decline. Trinity or equivalent for building common areas. Fast and efficient on cgd and very profitable. Lower entry cost.
I just bid on a pair of building’s...
Combined, it’s a 8K a year contract....
The last guys used a portable, and the halls and common spaces are in DIRE need of a proper flushing....
450-500’ hose run.... once i get it back to normal, I’ll run VLM...
Steve Shotwell
Any sized imo.
Encapping is using a fiber pad and trusting your encap juice to capture (Encapsulate) all the soils
Padcapping is using an absorbing pad to capture 90%-95%-99% of the emulsified soils into the pad.
I dont Encap...i Padcap. 🤷‍♂️
Maybe we're just madcapping.
