- Joined
- Oct 6, 2006
- Messages
- 117,323
be forewarned
. dont go buy a new Tundra or something stupid.
Using a scrub pad instead of an absorbent bonnet.Any sized imo.
I'll be honest and say I never use the term "pad cap"... not even sure what the hell it means maybe you can explain it to me
Only if you use a Cimex machine. I use scrub pads all the time with the sprayborg. Works great.Stupid
Thats called Cimexing.
You will remove more soil with a microfiber pad for sure. As long as you change the pad regularly. But encapping with a scrub pad gives you the exact appearance. If it works for a Cimex, which is considered the king of encapping, it works for all of the orbital machines as well.Well I guess I just prefer to remove some soil
You just dont understand“Some”
You’re embarrassing
Not meSo would you ever build a small van such as nv200 and an encap crew to go do apartments and commercial work
No truckmount
Tons of chit carpet
And probably piss lots of piss
I don’t think I would either but I would like to setup a van for apartments and things I can’t do with the big vans and let them go to workNot me
I would consider setting up a van like a transit connect with a combination of high performance portable and an orbital. Portable for apartments and orbital for cgd. Get you in the underground parkades.I don’t think I would either but I would like to setup a van for apartments and things I can’t do with the big vans and let them go to work
But in the end I think customers would complain about the process
Techs would complain about the weight of the machines and I would bitch about how much they complain
That’s a good idea Ron...I would consider setting up a van like a transit connect with a combination of high performance portable and an orbital. Portable for apartments and orbital for cgd. Get you in the underground parkades.
For a large metropolitan city, you would never run out of work. Tons of condos with lots of Upholstery even if carpets are on the decline. Trinity or equivalent for building common areas. Fast and efficient on cgd and very profitable. Lower entry cost.That’s a good idea Ron...
I just might see how well that works out...
I just bid on a pair of building’s...For a large metropolitan city, you would never run out of work. Tons of condos with lots of Upholstery even if carpets are on the decline. Trinity or equivalent for building common areas. Fast and efficient on cgd and very profitable. Lower entry cost.
Used my TOPS spotter sample today on a filtration line/mold and it seemed to work good. Haven't had a chance to test it out on anything else yet, but so far so good.
Any sized imo.
I love off the cuff figures
Maybe we're just madcapping.Encapping is using a fiber pad and trusting your encap juice to capture (Encapsulate) all the soils
Padcapping is using an absorbing pad to capture 90%-95%-99% of the emulsified soils into the pad.
I dont Encap...i Padcap.![]()
