What sealer would you use for a new Travertine floor install
Heart of Dixie
What I use after polishing (which would be analogous) is a solvent sealer. It absorbs at different rates and needs a wipe, but dries without a haze.
Reactions: FB7777
Doug Rice
Is that something you should let cure a few days before sealing? I use the stuff from Cobb's and have good results with it.
FB7777
The plan is to clean the tile after installation Of tile and grout but prior to the kitchen install
there is an island , half wall, wet bar all plumbed and ready
the final clean and seal will happen in a month or so after completion of all construction
it’s a twofer
FB7777
Great questions , thanks
I haven’t seen the install yet
been working on this house for over 20 years
he’s living in his Cape home until the renovation is complete
Doug Rice
The grout might be full of construction debris before you get to it. If it's sheet rock dust you will be the one looking bad.
Reactions: FB7777
If its not too late, suggest he use this grout for the install.
The color consistency is amazing and the lack of sand will enable easy future resurfacing if desired.
Far more stain resistant too but seal it anyways
Reactions: FB7777
FB7777
These guys are top notch... each work area has zip walls .
The GC is a friend , I’ll reach out Monday AM to make certain they thoroughly clean area before grouting
clean image
Orlando
Carl Maddock
Depends on type of Travertine/ installation:
SE, butt install or castle install(AKA:french pattern, ashlar) , is it factory filled or un filled post filled?
Is there any refinishing going to be done post install?
You also need to make it very clear sealing will not change the appearance, and set expectations.
Basically, depends on how absorbant the surface is to match correct sealer for best results and ease of application
Would not recommend Prism, as it may surface damage a polished surface,
Custom has also updated there unsanded line i noticed, unsure, however may be using similar type cements (color fast and quick cure)
