Auction Saiger Chemical Package
Village Idiot
Auction includes:
  • One Case of Saiger's New OdorOxy with Mango Cide
  • One Case of Saiger's NEW Eloquence for Upholstery, Fine Fabrics and Wool prespray cleaner
  • One Case Saiger's P-Zyme with Eucalyptus Mint Odor Destroyer (Bacteria Enzyme)
  • One Case Saiger's Mango Burst Scentsation
  • Free shipping to Lower 48
OdorOxy Urine Odor & Stain Destroyer​
True odor elimination chemistry. Can be sprayed and walk away to continue working on stain and odor. Eliminates stains and odors. Powerful oxidizers. For use on carpet, upholstery and other fabrics. Effective on pet stains, blood, coffee and tannin stains, vomit and other organic stains. Pleasant scent **description for Odoroxy but you will receive the new product with "mangocide".**
Eloquence Upholstery, Fine Fabrics & Wool Pre-Spray​
ELOQUENCE is a very unique Upholstery, Fine Fabrics & Wool Pre-Spray Cleaner, which has been field tested by the Saiger Family for quality assured performance. Eloquence field testing was performed in many areas of the U.S. as to ensure maximum safe cleaning performance regardless of conditions.
UN-EQUALED COMBINATION OF PROPRIETARY SURFACTANTS Our specific blend of wetting agents and emulsifiers are designed to remove tough oils and soils commonly found in upholstery fibers. Eloquence was designed for improved cleaning performance specifically for those difficult fine fabric/wool cleaning challenges. Eloquence has an un-equaled ability to cut through body oils, odors and every day household wear and tear of your fine fabrics and wool carpets/rugs.
POWERFUL CLEANING ABILITY FOR THE MOST DELICATE FIBERS Saiger’s “Eloquence” can also be used on carpets and rugs where a lower pH is needed. You will see incredible cleaning & brightening properties not typical of products in this pH range. Our proprietary blend is a non-foaming formulation, making it easier to use.
Saiger’s P-Lime-Zyme​
Saiger's P-Lime-Zyme is a ready to use active solution with a special blend of odor counteractants to immediately knock down and keep odors suppressed while bacterial enzymes go to work. Pet Stain & odor destroyer contains bacteria that produce multiple enzymes to digest odors at the source quickly and effectively. It will eliminate odors caused urine, feces, grass, mold, mildew, organic rot, vomit, smoke, skunk, and more.
Saiger’s Mango Scentsation Deodorizer​
The Burst of Exotic Mango with a hint of Juicy Orange and fresh Pineapple splash your senses with the new Saiger’s Sauce “Mango Burst Scentsation” Deodorizer!
This water-soluble deodorizer is a great additive to your cleaning solutions or an after spray for a delightful tropical experience!
Packed full of malodor counteractants, it helps neutralize those nasty odors, or a nice way to complete your clients total cleaning experience.​
$369+ Retail Value
Free Shipping to L48
Starting bid $190
Minimum bid increment $5
Auction ends Tuesday 12/15/2020 at 9PM EST / 6PM PST
  • Wow
