- Oct 6, 2006
- 117,209
21.Wicking (or reappearing spots or soil)
Wicking, a common cause of recurring spots and stains, is a term used to describe the upward migration of water-soluble materials on carpet fiber surfaces during drying.
Regardless of the method used, carpet cleaning cannot always remove 100% of the soil deeply imbedded in the carpet fibers.. A certain amount can be left behind at the base of yarns and on the carpet backing. This soil can move from the base of yarns and backing materials to the yarn tips, where it becomes a visible spot again after the carpet dries.
Care tips:
If your carpet is experiencing wicking after cleaning you can try these easy steps to fix the unsightly areas
-Let the carpet dry thoroughly for at least 48 hours
-Vacuum the area with a brush roll-equipped upright vacuum, slowly and from three or more directions
-Lightly mist distilled water on the affected area and gently blot with a microfiber (preferred) or white cotton towel. Look for soil transferring onto the towel.
-If effective, continue to lightly mist and blot, until the carpet’s appearance returns to normal. 3% Hydrogen Peroxide works well too and will not cause a bleaching effect. Make sure it's a fresh, unopened bottle.
-Let the area dry and inspect
-If the carpet still does not look normal (keeping in mind that wicking usually occurs in high traffic areas and wear may still be obvious), consult with your IICRC Certified Technician to set up a return visit or for suggestions on what cleaning solutions would be best for your carpet type.
Would you mind asking your wives read this and ask if it makes sense to them?
Care tips:
