SS 12" vs` PMF Mach 12"
Johnny
Johnny
Was having shoulder pain about a year ago. PMF Mach 12 was the lightest wand I could find. Replaced the PMF single-piece slot glide with a GreenGlide hole glide because it was easier on my shoulders. The steel lips are also removed to fit the GreenGlide. It seems almost too light, but works well for me, and my shoulders are good.
Is the SS 12 any better than a Mach 12 with GreenGlide?
The jet placing is as perfect as the Dev12, making it feel and look like you are cleaning with a single jet wand. ( the M12 stock jetting placement is horrible
Airflow is noticeable better as well.
Reactions: Johnny
Johnny
Johnny
Just wondering whether the difference between the two wands is worth the $, now that the lightweight Mach 12 has achieved its objective of helping my shoulders.
You already own the Mach 12 so it's probably not worth spending another $1,200 for a little bit of increase in vacuum and better jet performance when you can tweak the Mach 12 jets with some cutting and bending to get them almost perfect, but if somebody were shopping between the two wands it's a no-brainer
icleancarpetz
Rafael Samson
Been using mach 12 for several years. Tweaked the jets with Joe Bristol jet paçk.
The glide believe it or not is the original Teflon glide I bought with the wand 7-8 yrs ago. And still going strong. Lost a couple of screws but still going strong. With out it, the wand locks on to the carpet...son of a gun to push.
love my Mach12.
love my Mach12.
you seriously tried to run that wand with out a glide?
icleancarpetz
Rafael Samson
When i first got it, i installed what i think were called ‘lip glides¿’ at the time. They were like crappy glides that wouldnt stay on. Took them off all together on the last job. What a bear it was to move the wand without a glide. I knew through that experience i had a kick azz wand. Called pmf and they sent me their glide. Still using the same one to this day. Slot Glide.
i also have the Mach15 2” tube. Beefy wand Very seldom do i use it anymore. Like new toys when they first come out, you play with it for a while then toss it to the side.
Gotta a punch of SS wands. Dont know what to do with them. Maybe melt them down and make some rims out of them¿
icleancarpetz
Rafael Samson
The PC tie was made to run without a glide remember it had metal lips forged into the head
The Mach 12 has no lips and is just a sharp edge All the way around and very wide open..
PMF did make a metal glide for it. I have them too. Just not the same push n pull like Teflon,
It was a terrible glide. My m12 titanium was not a friendly tool with those lips. I got rid of it very soon after
icleancarpetz
Rafael Samson
Huge gap is good on a wand so long as the rest of the airflow intake is properly designed and not restricted by just two pieces (head n tube) welded together and you are using a good match, engine to blower combo. Using a high air flow wand with a portable is a waste of both money and effort. In that situation you want a wand that restricts air flow in order to get somewhat decent air intake from the blower motors on a portable or you could restrict airflow some by using a whole glide or a slot glide that lessons the gap and restricts airflow. Im not an engineer by no means but i think I’m right.
You want a wand that manages air flow...
From the carpet to the vac cuff.
Very few do.
as an ex "over thinking rocket surgeon", I'll suggest building the "perfect wand" that needs to be choked down is an example of a malidy called ORSS (overthinking rocket surgeon syndrome)
problem with over wide slot isn't with the vac system (any #4 blower has more than enough)
it's when the slot is too wide, the interface slot angle position becomes more critical to prevent HG lose...or in layman's terms, "you lose suck" at the fiber if/when wand position isn't on the money
Reactions: icleancarpetz
What happened to Tom’s lift adjuster that he had on the front of the glide.
The idea was to turn up the lift on the tm (15+) and crack open the air port on the glide for that to be the vac relief, causing the air flow and lift to work together more.
Did that idea fail?
I thought you said “ex”?
I am .
In the sense I determined thru trial, error and constant evaluation of 20 years full time wand sloging that going to the "oomph degree" on this stuff has little "practical" value in reality
the moral of the story is ...
"don't overthink it"
given your capacity, that should be easy for you...
Did that idea fail?
nope, worked great. But "you" wont even pay for his wand, you certainly wont pay for that complicated contraption.
Reactions: hogjowl
Did that idea fail?
ORSS
..L.T,A.
Meter Maid
The Undetective
I owned the 12 inch Devastator. Sold it, even though I shouldn’t have. But if I still had it, I would still use the sapphire 12 inch.
Weight matters when you do thousands of reps per day.
The swivel adds weight.
I’d say the SS12 has at least the same airflow as the Devastator. But it’s much lighter and is a joy to use.
The only thing I miss is the window.
  • Eyeroll
Reactions: hogjowl
Did that idea fail?
It infringed on Nellos' patent...
If a wand works better on a truck mount, it will also work better on a portable, vacuum wise. better air flow is better air flow.
Did that idea fail?
I can remember Duane Oxley posting something similar, dont know if he ever made anything
