Whip hoses...
I used both sapphire wands yesterday with and without a 8' whip.
I've come to the mature veteran cleaner conclusion that only idiots asking for joint issues, wouldn't.
If you know how to wand, 2"straight might cut off 5 minutes of dry time on a humid day with the windows closed and a plugged up filter.
San Francisco, CA.
Using 1 1/2 wands are a great relief after a long day--- when using a 2" hurts your Virgina. 🤣 :stir:
yes-- I DO use the 1 1/2 SS wand sometimes.
John Olson
Orem UT
John Olson
My how things have turned, LOL If you had said that 10 years ago you would have laughed your own ass our of here brother :) But you are correct. a dry pass with a glide and a whip will be less stress and make zero difference then running 2" to the wand for the customer but will make a difference on the cleaners body at the end of the day..
I would still like to find a softer 2 inch whip hose that won't kink. Using 2 inch to the wand today. Nasty feces and urine so I wanted the best extraction I could get. You can definitely feel the difference from a 1.5 inch wand. I don't mind using the 2 inch wand, it's that heavy hose behind you, knocking pictures off the wall or knockin over expensive vases, etc.
  • Wow
Reactions: Kenny Hayes
No
I tease him, but Mike’s ability to grow beyond past beliefs is something that I respect, even when I disagree with a particular new view of his.
The 2014 Mike would have never lent my father the support he needed when he had to replace his last IICRC shareholder representative.
If Mike could be “bought”, I wouldn’t be here.
Meter Maid
The Undetective
Dayton,Ohio
No
Marty...
