Whip hoses...
Yukon, Oklahoma
The debt usually always happens when acquiring a biz. When I was in the insurance agency biz, we acquired an agency and the same occurred. The good thing about it is, usually it can help tax wise.
Meter Maid
The Undetective
Dayton,Ohio
40,000 posts of nothing to say
one note Marty
if you ever had the inclination to learn a musical instrument , I recommend the triangle ....
better yet , go with a metronome .... it will relax you as you transition to your final nap
I agree that Marty should just let go. Bless his damn heart.
Trip Moses
IMOL
Savannah GA
Trip Moses
Want faster dry times?
1. Move to Nevada
2. Don't pre-spray so far ahead of yourself.
3. Don't trigger the wand on the forward strokes.
4. Clean your filters more often.
5. Do more dry strokes and be deliberate about them being sure to overlap especially on the ends of the stroke.
6. Use good chemicals that rinse freely.
7.Move to Nevada
Why are defoamers always left off these lists?
Cause it’s not 1973
Dinosaur story time.
In the 70’s we sold defoamer, antistatic spray, and browning treatment by the 5 gallon pail, multiple cases, sometimes 55 gallon drum.
In the 80’s and early 90’s, by the case.
Since then, no more anti stats, and the other stuff by the gallon.
Now, we dust off the individual gallons that sit on the shelf.
Trip Moses
IMOL
Savannah GA
Trip Moses
if I go through half a tub a year of defoamer, thats pushing it.
It takes less than a minute to sprinkle some around. If you get into the habit of doing it your levels of extraction stays consistent on every job. Every job doesn’t need it. But it makes every job better. Only takes a little product and a little time. I guess I like that 70’s groove.
San Francisco, CA.
I did a few rooms with the SS14 an no whip the other day.
Not worth the effort.
I gave the 2"Dev14 a rest yesterday and used the ss12 without a whip yesterday and it was a joy.
I thought the 14 would be faster than the 12-- but I'm beginning to have my doubts.
I might have to follow @Mikey P and replace my Dev14 with a Dev 12.
Disclaimer: If I still used a TM with a 5.9 blower- I believe a bigger wand would be faster.
The wand and technique should be adjusted to the equipment used.
I dont follow many sudsy cleaners and am 60% repeat
I'm not vury good at math, but know how to work a calculator
on a 16ft wide room, 2" wider stroke cuts 3ft off the width
on a 25x16 room, 2" additional shaves 75sf of strokes
75sf X's 5 or 10 rooms a day adds up
the question I wonder, what's less stressful on the body long term?
It's all about years and years and decades of physical repetitive motion that causes pain great or small to all eventually
so I wonder
20% more strokes and time per room with a little easier push, or 20% less strokes 'n work a day with more productive head ?
:headscratch: donno
La La Land
so I wonder
:headscratch: donno
Wait....we are still talking carpet cleaning...right?
Meter Maid
The Undetective
Dayton,Ohio
There’s a really good chance you will not like the Dev12 as much as your SS12.
Reactions: Papa John
San Francisco, CA.
so I wonder
:headscratch: donno
Its seems less strokes are needed with the 12 inch wand because More water is removed with each stroke.
Odd- i agree.- but 12 works better with smaller blower.
1 stroke was all i needed w the V.
Bob Savage
Dayton, Ohio
Bob Savage
I have not had a piece of 1.5" vac hose in either van for 25 years!
I use a piece of flexible 2" hose going to the wand with a hose cuff for conversion if need be for 2" hose to 1.5" wand.
