The 370 has been extra hot lately...
My unit is over heating and shutting down even when waterbox/heat exchanger has water flow.
It only happens when temperature thermostat is on.
Filter is clear.
I think the Bimba needs to be lubed.
Any suggestions
Filter is clear.
Any suggestions
ky jelly
Reactions: Papa John
I discovered why my 370 was over heating:
SS 12 wand had only #4 flow and
Too much oil in blower.
:headscratch:
over fill can blow a seal, but doesn't cause excessive heat.
the flow doesn't make sense either .
How could someone use hand tools or most all upl tools??
jack zerkie
I got HOT today working on 2nd floor then no water from wand engine running fine, Ran down to hose and someone turned if off, The temp gauge was past 240 no water just steam. I stopped the unit and nothing but steam from the hose. lost track of time probably 5-8 minutes running no water. After 10 min. I restarted and no problem all is fine back to work. I had the customer stay at the hose so that I could finish. Thats my old Cobb 2045 can't kill it. Just another great day on the job. jz.
:headscratch:
I also greased the bimba.
I've had people do that before.
