have you ever stripped a floor with out needing to scrub?
I get to remove one thin coat of Bona topical off a solid plank floor today, is it ever this easy?
Matt B
Florence al
Matt Briseno
No , but possibly if it’s actually only one coat, u can keep solution spread around so it doesn’t dry in spots and u rinse it quickly. It’s possible 🤣
  • Wow
Yukon, Oklahoma
Used a square scrubber with SPP pads. Just vacuumed up the wax. Noisy and dusty mess but no stripper.
That will do it. It will do it on vinyl too. But I tried
to share that wisdom on another board and of course they said that, and I was stoopit. Kinda like hwe or low moisture🤷🏼‍♂️😉 I told em to bite
me, you can’t fix stupid!
Nevada
You can always call trooomen steemer to coach you, if you at loss...
Well whatever is in that bona high gloss finish It's nothing like a VCT wax that puts pounds of plastic goo in your paint filter
Reverse fade, it happens
Oh, so you didn't try to fix it. You made it look like you had a secret miracle to fix that fade.
That floor didn't look that bad. I'm trying to find areas that showed somewhere where your services were needed. I see some lighter colored lines in between the planks. Was that where the wax was showing? Otherwise, it looks like you didn't do anything
The Bona finish layer wouldn't show up in pics...
