- Oct 6, 2006
- 116,979
I get to remove one thin coat of Bona topical off a solid plank floor today, is it ever this easy?
And don’t use a big box retailer stripperI'll bring the 175 just in case...
you no like the Zeps?And don’t use a big box retailer stripper
sorry, wood, dark wood.Solid plank floor?
Is that wood or vinyl?
Do you plan on stripping and applying water based poly or just stripping and cleaning?sorry, wood, dark wood.
That will do it. It will do it on vinyl too. But I triedUsed a square scrubber with SPP pads. Just vacuumed up the wax. Noisy and dusty mess but no stripper.
What happened to that corner area?
Um NOyou no like the Zeps?
Reverse fade, it happensWhat happened to that corner area?
SnobUm NO
Oh, so you didn't try to fix it. You made it look like you had a secret miracle to fix that fade.Reverse fade, it happens
The Bona finish layer wouldn't show up in pics...Oh, so you didn't try to fix it. You made it look like you had a secret miracle to fix that fade.
That floor didn't look that bad. I'm trying to find areas that showed somewhere where your services were needed. I see some lighter colored lines in between the planks. Was that where the wax was showing? Otherwise, it looks like you didn't do anything
I'm done in these pics..
Reverse fading phenom...View attachment 106538View attachment 106539
