rick imby
- Jun 5, 2009
- 2,210
- Name
- Rick
So I have issues with vacuuming stairs. What is your solution?
A small motorized brush hand vac.So I have issues with vacuuming stairs. What is your solution?
Can you explain in greater detail? I'm not familiar with what you're describing. ???So I have issues with vacuuming stairs. What is your solution?
Which one? ThanksA small motorized brush hand vac.
Stairs and upholstery Amazing what accumulates in the container. Justifies $75 per set of stepsView attachment 107149View attachment 107150View attachment 107149
Yes, It tends to fill up on certain jobs. I try to zip main vacuum over really bad steps before using the hand held. But what is nice is its easy to pop apart and dump when needed. Stick hose cuff from van on filter when done. Less mess.I found that that filter plugs up halfway through the average staircase...
Right now I am using a shark stick vac. It collapses to a handheld and also makes a great edging tool. Downfall is small canister. I bring a garbage bag to empty it.Which one? Thanks
Ugh is right. We should charge a whole lot more for steps.
