- Oct 6, 2006
- 116,839
What do you think of this layout?
lots to take in....
lots to take in....
Looks more like a coolant overflow tank.I suppose if ALL YOU DO is HWE carpet its sort of cool.
But tell me, how do you dump your rinse agent into the tank.....
Nope, its the chem, they say it slides out. Which means do put anything on the floor infront of it and leave room all the way to get back there a few times a weekLooks more like a coolant overflow tank.
I think the orange line wrapped around the pump is the chem feed.
If that's the case I sure after a couple of times changing it out most would replace it with a jug sitting next to the machine but will still be a major pia to get to crawling up in the truck.Nope, its the chem, they say it slides out. Which means do put anything on the floor infront of it and leave room all the way to get back there a few times a week
My 370 and essentially the same van allows me to be a multi-service service provider..If it’s reliable, and not so stupid it can’t be serviced easily, it’ll be fine.
You’re 370 isn’t the greatest thing since sliced bread either.
Love machine and the 210 recovery tank but their vac reel sucks. Won't hold much and poorly constructed. Broke spokes on 3 different trucks.
wow that is interesting. I have had 10 vans over the years and never had a problem with reels. If you use 2.5 inch hose, I can see the complaint about hose capacity.Love machine and the 210 recovery tank but their vac reel sucks. Won't hold much and poorly constructed. Broke spokes on 3 different trucks.
No just 2 inch. We actually found the Butler in a box to be the most versatile also. We used the standard extended Van's for carpet cleaning.wow that is interesting. I have had 10 vans over the years and never had a problem with reels. If you use 2.5 inch hose, I can see the complaint about hose capacity.
We used 250’ of 2.5, then 100’ of 2...wow that is interesting. I have had 10 vans over the years and never had a problem with reels. If you use 2.5 inch hose, I can see the complaint about hose capacity.
Name one manufacturer who makes only one machine.The flaw for steamaction is they should just stick to one machine.
Maybe a 45 or 47 blower to sell to the masses. It seems no one model is the same. And I agree a coupler sucks ass.
Aerotec until recently.Name one manufacturer who makes only one machine.
El Diablo.Name one manufacturer who makes only one machine.
they made 3El Diablo.
