- Feb 4, 2016
- 24,129
Man. That oink and yellow is really bad. You should fix that.
I meant I knew the cleaning wouldn't be an issue for you. The problem was obvious due to the clean spot around the stain and the rest of the furniture didn't look bad just the seats. And I was concerned the stain would still be there. That was the problem I saw for you.Matt
As I explained earlier, the pink and yellow was a camera thing. It isn’t there in reality.
No Steve, the stain was not the issue with the customer. It was the “stripes” or left behind soil.
How does concentrating help take the edge off?Jimmy, TopSpot is concentrate, maybe that’ll help knock the edge off.
If I'm worried about the edge and I concentrate I am concentrating on the edge.By taking your mind off the edge
But, of course, in your case that’s not do easy.
So what caused the stain you couldn't remove.Thus the reason you’re so weird
I told you he gives me a headache!How does concentrating help take the edge off
We are all so thrilledI'm just thrilled that Marty started a thrilling thread.
