- Oct 6, 2006
- 117,327
How's that fine Detroit steel, that Bob sold you, here, right under my nose, treating you?
that Bob sold here right under my nose?
Fred ....the way THAT deal went.....can you believe that sob still hasn't sent me my cut?
Sounds to me lik YOU owe Fred a cut....Can you believe I still have yet to receive it?
The crating place I dropped it off to get crated took basically 3 months to crate it.. Supposedly they got new owners and the place was a sh!t show.. Took weeks just to get a reply.. Then the lady didn't reply to the warehouse guys..
It took Keith and I about 2 hours to pull everything and then drive that (heap of a van) to the scrap metal.. They gave me $1,000 for it, plus I found some money behind the center console as well.. Thanks Bawbby or Crash..
View attachment 112463View attachment 112464View attachment 112465
So Nate....as you can imagine...I couldn't WAIT to send CRASH that picture....and he sez that was his hiding spot and he wants his cash back.....he DID sound a little ill afterCan you believe I still have yet to receive it?
Should have bought an Amtex
Nice find on the cash!
Wait till I show CRASH the money shot....
If I didn't throw in the extra money, I'd have not Juan but basically 2 free Steam Genie's.. If you’re talking about that thermal wave…I’m trying to keep the headers cool enough to jot glow red. I’m gonna get some new o2 sensors this weekendNaw, seller pays fee's..If I didn't throw in the extra money, I'd have not Juan but basically 2 free Steam Genie's..
They may need more work than @Matt Wood wanding technique, but a real gem.. Still a better but than his Monaaay pit Screwline machine..
Speaking of which, how's that machine working out for you Matty boy?
Seeing the pic.....
Glad to see you back Nate.
I Hope your return lasts longer than Boyle's did.
I only need to last long enough til I receive my rug squeegee.........![]()
I’d rather have his rug SqueegeeIt should already be on it's way...........but I'd rather you just stuck around.......following the rules of course
I think I can make a rug squeegee out of 1971 Ford bench seat parts.
As much as the TRAILER?If you’re talking about that thermal wave…I’m trying to keep the headers cool enough to jot glow red. I’m gonna get some new o2 sensors this weekend
I was definitely regretful in buying it
Nates "bedside" manners are quite more tasteful than the boils ever were! An that ain't the fortune I made from him talkingI only need to last long enough til I receive my rug squeegee.........![]()
Nates "bedside" manners are quite more tasteful than the boils areI only need to last long enough til I receive my rug squeegee.........![]()
Sh!t I should be thanking you for "giving me" 2 free steam genie's..
Better choice or sucker?Nates "bedside" manners are quite more tasteful than the boils are
You are quite welcome sir... can't think of anyone a better choice
Most direct drives get whatever temperature the engine runs at. Not really any need to regulate the heat unless you don't want hot water for some reason but the Cleanco and hydramasters have had a control that bypasses the heat exchangers. I disabled it on my CDS as it was leaking. My Cleanco has an adjustable bypass so you can get less heat or no heat at all. Unlike exhaust heat exchangers, there is no need to bypass to the waste tankSo a lot of you know that I'm used to Little Giant Heaters.. Simple easy to operate..
My question is, how does the Steam Genie regulate heat? It has a John's Custom Coolant HX..
Does it just give you whatever thermostat you got in the engine? Say it's a 210° thermostat on the engine, I'd probably get a constant 190° at the wand?
Is there a way to regulate it or it's a always on system?
The whole point of going direct drive is that I don't like my doors being left open with my expensive toys/tools left unattended.. And filling propane, it's at $5.83-$6.00/gal.. And the sound of my lawnmower engine as well..
The way Bawb had the Genie setup with the stainless steel ceramic coated mufflers, it's super quiet compared to what I'm used too.. And for being 10years old in Michigan weather, the damn thing still looks new inside and out..
Some things you don’t know that you don’t know.. You have the known knows, and the unknown unknowns..Most direct drives get whatever temperature the engine runs at. Not really any need to regulate the heat unless you don't want hot water for some reason but the Cleanco and hydramasters have had a control that bypasses the heat exchangers. I disabled it on my CDS as it was leaking. My Cleanco has an adjustable bypass so you can get less heat or no heat at all. Unlike exhaust heat exchangers, there is no need to bypass to the waste tank
That should be fine. The water coming off the pump is cold.Some things you don’t know that you don’t know.. You have the known knows, and the unknown unknowns..
I ASSume I can put a Tee on the pump and run a “second qc to another line.. 1 line goes through the HX and the other is bypassed.. Use a Y to lessen the heat?
I ask because some upholstery I don’t like to hot hot water..
