- Feb 4, 2016
- 14,637
- Name
- Matt w.
Its not Eneptune.It's probably Goodyear Neptune hose-
It's my Favorite after buying other hoses taughted on this board.
Do they come with stainless ends to keep the rust away ?Well I guess I shouldn't say that but I know when they bought our last Aerotek in 14 it came with some other steel braided hose and the blue dye was rubbing off everywhere. So they graciously replaced it with Parker 1035 HT after I signed a disclaimer saying I wouldn't sue them if and when it blew up in a customer's face.
1035 is still my favorite hose but I haven't used it since moving to Nevada as I can't get it repaired here
Actually Joe hose repair crimps work on that hose great, it works on oem, which is a parker knock off.Well I guess I shouldn't say that but I know when they bought our last Aerotek in 14 it came with some other steel braided hose and the blue dye was rubbing off everywhere. So they graciously replaced it with Parker 1035 HT after I signed a disclaimer saying I wouldn't sue them if and when it blew up in a customer's face.
The outer skin on mine marked up quickly, but is a decent hose to work with. I have been using for about a year now. I bought a second 125' length at the first if the year, so I would recommend.I’m loving these hoses so far. Not stiff, insulates the heat well, and is a rough feeling surface that isn’t bleeding blue when wet. I’ll keep you up to date on it as time flies
The red heater hose serves the function of bend restriction, heat protection, and blowout deflection.
I’m tired of our industry putting out shitty hoses.Matt, you know how to over-complicate an issue better than anyone.
Guess, it's funner that way.What am I doing to make this complicated?
Cobb's OEM is a joke alsoParker is a damn fine hose..
I did want to try that OEM hose Cobbs had.. @Shane T spoke good of it and he was running a #3 LG heater..
I remember seeing @GeneMiller use the clear vinyl hose as a deflection hose.. You could see if it was leaking..
turn your heat down.What am I doing to make this complicated?
They all blow out black water in 6 months
If you don’t do tile go with parker.
I prefer Goodyear neptune. Just goota replace once a year before it bursts. I got three years out of my last Goodyear before it sprayed black death all over the ceiling of a doctors office.
Hi temps and PSI wear it out fast. Seemed like everytime I did a tile job with parker I would immediately have issues a few days later. After discussing it with Tom Conway we figured out that the lighter hose was not the best for the temps and pressures of tile cleaning.What kind of failures did you have when you used Parker, Damon?
and what's the highest PSI you run on tile?
