This is your competition..
FB7777
Watched the first 30 seconds …. Yawn
just finished binge watching Super Pumped the fight for UBER
I prefer to watch videos about billionaires than brokenaires
Reactions: Kenny Hayes
Crunchy.
That line of foam he's leaving at the end of his stroke tells me he's not getting it rinsed out.
Doesn't look hot neither.
Reactions: Hack Attack
You are assuming he started at the door, and would be wrong.
He choice of direction for the doorway and behind the door is ideal for the first 2 cleanings- then followed up with working the way out the room.
I noticed he had "cleaned" the other part of the room 1st. But would have used a 360iBH instead.
I have no idea how you 98%'rs think
Clean as a Jimmy
After a mud bath with Benny
Mr Brightside
Jay Wags
Honestly besides flooding the carpet on the backstroke and awkward cleaning angles fighting the hose while cleaning and lack of efficiency I think he is doing better than most.
He is in a uniform he has a walk off blanket and a cool pocket for his spotter to hang from
I think he is doing fine
Reactions: Papa John
No, he's not.
If it was pre-sprayed, not sure, it should have been scrubbed in and most of those spots would have been broken loose.
His wand technique is crude and will cause overlap wicking.
I think he may be hooked up to the kitchen sink faucet..
Mr Brightside
Jay Wags
I’m just trying to stir the pot
I didn't say he was perfect.
I was just saying the way he approached the door area and behind the door was fine.
He has a lot of improvements to make:
Needs more dry extraction passes.
better wand with glide
jets with less flow maybe- looked like he was flooding the carpet.
A rotary or CRB.
2-inch vac Hose instead of 1.5
🤔His solution hose looked like clear vinyl?? 😱 So maybe just Tap water.:dejection:
Numero Uno
Caesar
If I had a beat up broken leaky Rug Doctor he would still not be my competition ...
